This problem is due to over powering the speaker. Amps have built in protection for both themselves and the speakers they are connected to. If you have the gain turned up too far on the amp, it can cause the amp to go into protection mode which will turn the amp off temporarily. You have probably noticed the speakers make odd noises or sound awful just before the amp turns off. Other issues may be that you have a bad ground connection to the amp. Check this connection at the amp and at the location the amp is grounded to. Follow the "-" or "GND" cable from the amp. if that connection is good, just turn down the "gain" dial on the amp about 1/4 and turn up the volume and see what happens.
