I am assuming that your camera uses and SD card to store the pictures.
If you remove the memory card from the camera, you should see a little slider on the side of the card that says "lock," it is easy to accidentally lock SD cards.
I have attached a picture to show you what a locked SD card looks like.\:
Here is another image showing the card in the unlocked position:
I’m happy to assist further over the phone at https://www.6ya.com/expert/cody_a1e78820c0d52932
If it is a SD card you probably have to slide the switch on the side of your memorycard to the other side. Good luck!
