Enterasys C3G124-48P 48-Port Gigabit Ethernet Switch (C3G124-48P-G) Logo
Posted on Mar 01, 2011
How i can reset the password in a enterasys C3G124-48, if lose it
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
12594
Points
39
Before trying anything too drastic, I'd try using the username "admin" without the quotes and leaving the password blank. If that doesn't work, then you'll have to use the reset switch that's located on the back of the switch (number 1 in the pic below). how i can reset the password in a enterasys - nickmyers46.jpg
The following steps are taken from the manual for the switch.
1. Press-and-hold the reset switch while the switch device is operational. This change of the login password to the default password will be indicated through CLI only.
2. Logon the device management. You can now logon to the switch through the console port and assign a new password using the command line interface (CLI).
Where can I find latest firmware?
googling enterasys ap3640 firmware update may yield useful results
How to reset ws-ap3610 factory default
And the next question will be what is the admin password?
Why not use the manual, or google and have everything solved in minutes.
2answers
How can i reset the password of my switch if lose it?
There should be a reset button on the back, that will remove everything on it. You will need a pen or sharp object to push down the reset button.
2answers
Way to reset the user name/password
only thing i ran into was this: try it.
Default Password for APC Smart UPS
Description
Manufacturer APC Protocol Multi Access Admin Model Smart UPS User ID apc Password apc
1helpful
2answers
Password recovery
You can only reset to default. Download here the manual and follow the instructions (Reset Switch)
http://secure.enterasys.com/support/manuals/hardware/4099_05.pdf
CAn I use Enterasys serial module for the RS?
Which serial module do you have? Is it a cabletron or enterasys-branded one?
Top Enterasys Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Enterasys Computer and Internet Expert? Answer questions, earn points and help others
