Sony Handycam CCD-TRV68 Camcorder Logo
Posted on Jul 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Transfer To DVD Gives an Error that indicates the content is copy protected
I have used brand new tapes for recording general holiday scenes. When I attempt to transfer to DVD using a Funai DVD recorder I get message saying it is not possible to copy the tapes as the content is protected against copying. Funai support state that the reason is that their unit has detected copy protection data on the tape.
A
Anonymous
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jul 29, 2008
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955918
Points
33084
Amazing, CCD-TRV68 is analog video camera and doesn't have any digital signal like copy right.
  • Anonymous Jul 29, 2008
    Please check the properties/ options of Funai DVD Recorder
1helpful
2answers
Why won't the Sony controls let me click onto finalize using a Sony TV w/recoder to transfer VHS to DVD?
Is the VHS tape you are trying to record a commercial VHS tape (movie)? If so, it may have copy protection on it. The recorder is probably programmed to prevent you from making and using DVDs of commercial copy-protected VHS tapes.
1helpful
I have a Toshiba dvr 7 vcr dvd recorder. It occasionally gives an error message 85 when I am trying to copy a VHS tape to DVD. What does this mean and is there a way around it?
Commercial movie VHS tapes have copyright protection added to the tape. There is hardware in the recorder (mandated by law) that will sense this signal and not allow copying of these tapes to another tape or any other media. There are hackers that have built devices and modified equipment to circumvent this, but you risk legal action if caught.
1helpful
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
1helpful
Dvd recorder has copy protected message
the tapes that you can,t copy are protected, manufacturers used to put a high pitched frequency on the tapes themselves, which would in theory cause a scrambled frequency. the only suggestion i have for you, is to play the tape onto a television, and use a camcorder to record the image from tv to camcorder, then camcorder to pc, and use some good editing software to create the dvd.
alternatively, you could try using a second dvd player, and use your recorder as the second device.
The final but more expensive option, is to look for a way to input the recorder, direct to PC. which you would use picture out, to graphics card input, and the red and white ( Audio ) for the stereo Sound output. does your player or tv have An spdif connection or similar, you may be able to output to camera, rather than to dvd.
Where theres a will, theres a way, but these are a few options.
****Please note:- this information is supplied only as you have the original Movies***
Bear in mind, it is illegal to copy protected content. However as you own the originals, this information is provided to enable you, to backup your Purchased Content.
Thankyou for using fixya.
Mike @ compurepair.
2answers
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Funai dvd rcorder will not record to dvd
Are you trying to record a VHS tape to DVD? This won't work if the VHS tape is a commercial (disney, dreamwords, etc) because of an analog copy protection scheme known as Macrovision.
If you are trying to record, say, a broadcast signal and it will record to VHS and HDD, but the DVD errors out, then either the DVD drive is bad, or you have the incorrect type of recordable DVD in the player...
2helpful
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
3answers
I recently got a Philips DVD Recorder/VCR: Model No. DVDR3510V/05; Serial No. 0751 010790. I have recorded a VCR tape and would like to transfer this to a DVD±R disc. Can you tell me how to delete...
After you transfer the data to the DVD, you can use a DVD editing program like the DVD remake found on this link
http://www.afterdawn.com/guides/archive/dvdremake_tutorial.cfm
and you can edit out all of the commercials
let me know if you have further questions with this
Creating a DVD from digital tape
i took my unit back to electronic express a chain here in tennessee
the guy was baffled at first
then he got a firewire and plugged it into the ilink place on the front of the unit and it copies my old canon recorded tapes just fine
what happened??? who the heck knows --- somehow the chip that prevents the movie copying was reading my old canon recorded tape as copyright -- this somehow bypasses that
if i am not mistaken you can buy attachments to make sure they fit your type of camcorder - my new sony hi def camera came with one - so i had no problem
here is the other kicker --- WHEN I CALLED SONY AND ASKED IF THE ILINK HOOK UP WOULD MAKE THE DUBBING WORK -- THE IDIOT SAID NO he was dead wrong
i will never buy another sony in my life
i stil have not tried to tape movies to dvd and or vhs --- but i already have the machine so i'm stuck with it
what i'd like to know is which combo units do NOT have the blocking chip
could somebody update on the law about this
thanks
i hope this helps
please let me know
14helpful
8answers
Dubbing vhs to dvd
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
