Decals, Emblems, & Detailing for Subaru Forester 2.5X L.L. Bean Edition Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need 2 ll bean emblems for my forester - Decals, Emblems, & Detailing for Subaru Forester 2.5X L.L. Bean Edition
Anonymous
Level 3:
  • Master 3,400 Answers
  • Posted on Mar 02, 2011
Anonymous
Master
Level 3:
Answers
3400
Questions
Helped
985120
Points
10767
My 2007 Forester LL Bean edition has a strange slipping sensation when backing out from my garage and then putting the car into drive and accelerating on a cold start. Any ideas of what it could be? It's...
sounds like the transmission is slipping-check to make sure your tranny fluid is at the correct level and if it is check with your dealer as they may be able to do a tranny service & adjust the bands.
Good Luck.
Maintenance check points for 24,000 miles 2007 2.5x subaru forester?
MAINTENANCE SCHEDULE WAS DUE 22500 SERVICE AND INSPECT AIR CONDITIONER FILTER / REPLACE ENGINE OIL AND FILTER / SERVICE INSPECT TIRE ROTATION. NEXT SCHEDULE MAINTENANCE DUE IS 30000.
5helpful
Installing replacement side mirror on 2007 Subaru Forester
yes... you'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you can access the bolts holding the mirror on and disconnect the wiring harness as well..
2007 Forrester - headlight bulb good but not lighting
You will need to look at the plug for the headlight. If it looks good, I would look for the headlight low beam fuse.
1helpful
Replacing headlight bulb........
there should be a collar that you have to take off first
Drowning noise
I think you meant to write: ...drones with a slight modulation like overly loud road noise.
Top Subaru Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Subaru Vehicle Part and Accessory Expert? Answer questions, earn points and help others
