Login to http://www.routerlogin.net username is admin password is password. If unable to use pin to hard reset the router. Button located on back says restore factory settings. push and hold til lights flash on front
What is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
The default logon for most routers is:
UserName - admin
Password - password
If that does not work you need to reset the router by inserting a paper clip or pen into the reset button on the back of your router. This process may be different depending on your router model. See the link below for a guide on how to do this.
Reset and Restore the NETGEAR device to Factory Default Settings
Factory default user name and password of Netgear n 300 router are user name- admin password- password
The default username and password for the N 300 is:
Username: admin
Password: password
If you have changed the default username/password and have forgotten it, you will have to reset the router to back to factory default.
WARNING: BY RESETTING YOUR ROUTER, IT WILL BE SET TO FACTORY DEFAULTS AND WILL HAVE TO BE RECONFIGURED
To restore the factory default configuration settings:
1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings
button, located on the rear panel of the router, for about 5 seconds, until the Power light begins
to blink.
2. Release the restore factory settings button, and wait for the router to restart, and for the Power
light to stop blinking and become solid green.
The factory default settings will be restored so that you can access the router from your Web
browser using the factory defaults.
Regards,
KYTechnology
The default user name and password is admin/password. This will only work if you have not changed the default user name and password. If you have changed them, you will need to reset the router. This will reset all settings to default giving you access to the router again.
To reset the router: Use a sharp object such as a pen to press and hold the restore factory settings button, located on the rear panel of the router (tiny button) for about 5 seconds until the power light beings to blink. Then release the button and wait for the router to restart and for the power light to stop blinking and become solid green.
Note: The default IP address for the router is 192.168.1.1.
Ftp://downloads.netgear.com/files/WNR2000v2_SM_01SEP2009.pdf
SOURCE: cannot get password authorisation for netgear router
The default username and password for the Netgear DG834G router is:
username: admin
password: password
If that does not work (i.e., the default password has been changed), then the only way for you to log into the router is to restore the router back to its default factory settings. Then you will be able to use the default username and password above.
To restore the router's factory default settings, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
SOURCE: about 108 mbps wireless router wgt624 netgear
HOW CAN I INSTALL MY NETGEARN 108Mbps WIRELESS FIREWALL ROUTER WGT624 v2.
SOURCE: need password for wireless router
The default login is user = 'admin' and password = 'password' for the router. Only type what is between the quotes. If you changed and forgot your password, there is a reset button on the unit. Press the button until the power light flickers (about 10 seconds). You should now be able to get in using the default login.
Ryan Bauer is a freelance writer located in Ozark, Missouri. He has written numerous articles and books, including "How to Improve Your Credit Score 100 Points in 100 Days." Bauer is an experienced automotive mechanic and computer technician.
By Ryan Bauer, eHow Contributor , last updated February 24, 2012
Wireless routers are used to connect computers into a network without running network cables throughout your home or office. Netgear wireless router settings must be changed using the router's Web-based interface. Any computer that is "hard wired" with a network cable to the router, rather than on a wireless connection, can be used to access the router. From the Settings menu, options such as "Encryption," "Network setup details" and "Passwords" can be customized.
On a computer that is connected to the router with a network cable, open any Web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, type "192.168.0.1" (without the quotes) and press "Enter." This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
Type "admin" in the Username field, type "password" in the Password field and click "OK." If the password fails, try "1234," "Password" with a capital "P" or "admin". Once you enter the proper credentials, the settings screen will open.
Make any required changes to the settings. Under Security section, it is possible to specify a new username and password for added security. Once you have saved your changes, close the window, and the system will automatically log you out.
