How good are you at soldering. the fuse is a 400ma 125v fuse, you can pick up a 500ma cylinder fuse at radio shack and wire. the 10v 1000uf caps can be replaced with the 35v 1000uf caps also found at radio but they are kinda huge. check the diode specs and find a compatible one at radio shack
can I use a thermal fuse from Radio shack in place of the FL231 micro fuse? the thermal fuse has a 250vac with a max current of 10a?
the fuse is a common te5 fuse but not sold in most stores 400ma 125v littlefuse wickman p# 39504000000. I order them buy the hundreds from newark com. theyre 40 cent apiece
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
This FL231 convergence fuse only can buy at Ebay.com only far as i know,RCA corporation have no outlet for selling tv spare parts anywhere in the states.
No,don't buy anythings at Radio Shack and replaced it for a modication of the original parts of the FL231 convergence fuse,because the FL231 convergence fuse is specially design for this purpose.Modication parts are not reconmented for repairing around this area,because of dealing with highvoltages and sensitive deflection circuitries area.
90 to 95% by replacing the FL231 convergence fuse,will solved this problems.The DL231 diode and the CL230 Radial capacitor hardly ever dies or never dies.
Thanks for the info. S only the fl231 needs to be replaced and the flyback needs resoldering. The dl231 diode
