Types of sdram - Computers & Internet
  • 4 Answers
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Posted on Mar 03, 2011
6ya staff
SOURCE:
Three things to consider when choosing memory
1) What is the Maximum TOTAL Amount, that the motherboard will support.
2) What is the Maximum Amount for EACH ram memory slot.
3) What type of Ram Memory is it?
A) What type is it?
Single-Data Rate SDRAM?
SDR Sdram which is erroneously just referred to as SDRAM.
Double-Data Rate SDRAM? DDR Sdram
Double-Data Rate 2 SDRAM? DDR2 Sdram
Double-Data Rate 3 SDRAM? DDR2 Sdram
(See? They are ALL ->
Synchronous Dynamic Random Access Memory)
Then you get down to the basics, that is really supposed to be known...........
B) What Frequency Rate does it operate at? ('Speed')
200MegaHertz? 266MHz? 333MHz? 400MHz? 533MHz? 667MHz?
800MHz? 1066MHz? 1333MHz?
C) What Voltage does it use?
JEDEC has set the standard for Ram Memory.
'High performance' ram memory may use higher voltage.
Example;
DDR Sdram
JEDEC has set the voltage standard for DDR Sdram at 2.5 Volts (DC)
That is what the factory has set as a default voltage, in BIOS Setup.
High performance ram memory? May be 2.6 volts, or 2.7 volts.
D) Ram Timings;
Shorter to explain this way,
http://computer.howstuffworks.com/ram.htm
http://www.hardwaresecrets.com/article/Understanding-RAM-Timings/26
http://en.wikipedia.org/wiki/SDRAM_latency
E) Whether or not ECC or Non-ECC is to be used,
http://en.wikipedia.org/wiki/ECC_memory
ECC ram memory is generally used in a Server computer.
The data (Information) is analyzed 2 to 3 times, before it goes through.
F) Buffered or Unbuffered ram memory:
http://en.wikipedia.org/wiki/Buffered_memory#Buffered_memory
G) Chip Configuration:
The black rectangle chips on the side/s of the ram memory module ('Stick'), are called DRAM chips.
They are arranged in an order, and connected via circuitry, to be accessed as the ram memory manufacturer has deemed.
This you shouldn't have to worry about.
In fact you can probably get away without knowing D) also.
What test is this for?
Post back in a Comment
Regards,
joecoolvette
Apr 17, 2013 | Computers & Internet
Whats my sdram capacity
HP Pavilion 9694C memory upgrade specification, Pavilion 9694C maximum memory, memory speed, and memory upgrade options. Upgrade memory on HP Pavilion 9694C upto a maximum of 256 MB
PC100/133 SDRAM DIMMs, with maximum 128MB per slot in 2 memory slots. The HP Pavilion 9694C takes the PC100/133 SDRAM DIMMs Memory Type.
Hope that helps.
Feb 16, 2011 | HP Pavilion 9694C PC Desktop
How many pins in the hyundai ddr 512mb?
SO- DIMM 512 MB 333 Mhz / 200 PIN PC2700 64Mx8
DDR SDRAM memory has 184 pins, where as SDRAM has 168 pins. DDR SDRAM Memory is a new type of SDRAM that is able to double the read / write speed of the previous generation of SDRAM memory. There are currently, PC2100 (DDR266), PC2700 (DDR333), PC3200 (DDR400), PC4200 (DDR533) These DIMMs are 184 Pin in size and are not interchangeable with older SDRAM modules.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 29, 2010 | Dell Inspiron 1525 Notebook
Can i use DDR2 RAM instead of DDR1
YES, if your motherboard accepts DDR Sdram, and DDR2 Sdram ram memory. If your motherboard has both types of ram memory slots.
BUT, you can ONLY use DDR Sdram, OR, DDR2 Sdram.
You Cannot use both types of ram memory in the motherboard, at the same time.
(BIOS will only recognize one type at a time)
NO, if your motherboard does not have ram slots for both DDR Sdram, and DDR2 Sdram ram memory.
Double Data Rate Sdram ram memory modules, have 184 gold plated contact pins on the bottom.
92 on Each side,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can click on the above photo to enlarge)
DDR2 Sdram ram memory modules have 240 contact pins.
120 on Each side.
Sep 04, 2010 | HP Computers & Internet
What type of RAM do I need?
This should be easy for you , just et this RAM specs for your computer this is a DDR with a Module Speed of PC3200, DDR400.
Jun 17, 2010 | MEDIONM 3 COMPOSER 5100 INTEL- (20023321)...
Wanting to findout what kinda ram i need to get for an upgrade. this computer only has 256mb.
SDRAM (Synchronous DRAM)
Almost all systems used to ship with 3.3 volt, 168-pin SDRAM DIMMs. SDRAM is not an extension of older EDO DRAM but a new type of DRAM altogether. SDRAM started out running at 66 MHz, while older fast page mode DRAM and EDO max out at 50 MHz. SDRAM is able to scale to 133 MHz (PC133) officially, and unofficially up to 180MHz or higher. As processors get faster, new generations of memory such as DDR and RDRAM are required to get proper performance.
DDR (Double Data Rate SDRAM)
DDR basically doubles the rate of data transfer of standard SDRAM by transferring data on the up and down tick of a clock cycle. DDR memory operating at 333MHz actually operates at 166MHz * 2 (aka PC333 / PC2700) or 133MHz*2 (PC266 / PC2100). DDR is a 2.5 volt technology that uses 184 pins in its DIMMs. It is incompatible with SDRAM physically, but uses a similar parallel bus, making it easier to implement than RDRAM, which is a different technology.
May 15, 2010 | Computers & Internet
Can I put different types of RAM on a motherboard?
Not different types per se, but you may be able to put different speeds.
Type would be like DDR Sdram2_bing.gif, or DDR2 Sdram for example.
Speed is a slang term for Frequency Rate. What frequency rate does the ram memory2_bing.gif module (Stick) operate at.
Example: DDR2 Sdram that has a frequency rate of 667MHz. (PC2-5300) MHz stands for MegaHertz.
Mega = approximately 1 Million. Hertz stands for Cycles per Second.
The above ram memory module operates at 667 Million Cycles per Second.
If you install two ram modules that have a different frequency rate, all the ram memory installed will operate at the slower frequency rate.
(Provided the computer will support more than just one frequency rate)
Have a computer in mind, or is this just a generic question? A what if?
Reply to your recent comment:
If this is in relation to two different manufactures of your ram memory, it shouldn't be a problem.
Where you may get into trouble in this area, is if one ram memory module (Stick) is generic, or low budget, and one ram memory module is a high performance gamer ram memory.
Without knowing the exact manufacturer of your computer, plus the Model name of it, and also knowing the information you have about your ram memory 'sticks', the following information is just generic, or general information.
High performance ram memory may use a higher voltage. Not always, but a good portion of the time.
High performance ram may also use a faster set of ram timings.
It may also have high density DRAM chips, and the chip configuration may be setup differently.
(The black rectangular modules you see on the side of a ram memory 'stick', are DRAM chips)
To explain so far;
SDR Sdram was the typical ram memory for years after SIMM ram memory.
SDR stands for Single Data rate.
Commonly just referred to as Sdram, but in actuality that is erroneous.
(Sdram stands for Synchronous Dynamic Random Access Memory)
Then came DDR Sdram.
Double Data Rate Sdram.
Then DDR2 SDram.
Double Data Rate 2 Sdram.
Then DDR3 Sdram.
Double Data Rate 3 Sdram.
1) http://en.wikipedia.org/wiki/SDRAM
(Anything you see on a Wikipedia page that is in blue, is a link to more information.
To further illustrate this,
2) http://en.wikipedia.org/wiki/DDR_SDRAM )
SDR Sdram specifications were all over the place. What was considered to be a standard for one manufacturer, differed for another manufacturer.
The JEDEC organization was formed.
JEDEC sets the standards for ram memory from DDR Sdram on up.
Voltage for DDR Sdram is 2.5 volts
DDR2 is 1.8 Volts
DDR3 is 1.5 Volts.
Ram manufacturers found that by upping the voltage requirement on high performance ram, the ram could perform, better.
Not true in all cases, as there is high performance ram that operates at the JEDEC standard.
Ram timings were also varied.
Also the chip configuration
Plus the density of the DRAM chip.
Unless it is a really cheap, generic ram module, (Stick), there will be a manufacturers code on the side.
With this code I can tell you the specifications of that ram module.
I can also explain
Feb 28, 2010 | Computers & Internet
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
I want to know if SDRAM and DDR@ are the same thing?
No SDRAM is single data ram, with 2 slots in the bottom and DDR is double data ram, with one slot at the bottom.
Aug 17, 2008 | Computers & Internet
ECS M925 1.0 sdramm to ddr memory
The normal DDR Ram is supported..It doesn't support DDR2..
Nov 03, 2007 | PC Chips (M925G) Motherboard
Computers & Internet Logo
Ekse
Marvin
Marvin
