Question about Sunfire True Sub MK II Subwoofer
Need to replace whole module. where to buy used or new one for sunfire true sub mk II.Pls indicate the cost. Thanks.
    Brigadier General:
  • 8,546 Answers
6ya staff
SOURCE:
How do i connect my subwoofer to my home theater
Easy. Your home theatre amp will have a sub or LFE output ( RCA plug ). You simply connect this output to the input ( usually the left side, or use a Y splitter and use left and right inputs, or the LFE input if your sub has it ). Then, you must turn the sub on in your recievers setup menu, and your sub should work.
Mar 03, 2013 | Sunfire True Sub MK II Subwoofer
Sunfire MK II Subwoofer hum. I have a Sunfire MK II subwoofer that hums when it is plugged in (it even hums when no signal is connected). I've tried multiple outlets on different circuits, but hum...
you have a ground loop issue you could purchase a ground loop isolator, jensen makes them for about 40 bucks.I have discovered that if you have cable tv, unplug the incoming cable in your cable box and see if hum disappears.
Nov 25, 2010 | Sunfire True Sub MK II Subwoofer
How to get rid of the hum
Check your cabling to make sure you dont have a ground fault. if you still have humming, buy a "groundless" adapter for your power plug (takes the ground away) and plug it back into the power outlet and I bet your humming will be gone
May 10, 2010 | Sunfire True Sub MK II Subwoofer
Needs repair - loud humming noises when turned on who are service agents in Melbourne australia
had the same problem, so I installed a radio shack ground loop isolator and fixed the problem, it has 2 rca plug inputs and 2 rca outputs, goes in-between the sub and the input cables of your system to the sub...that's if your using the rca inputs..
Aug 04, 2009 | Sunfire True Sub MK II Subwoofer
Blown Driver Sunfire MKII True Sub, looking for replacement woofer.
http://www.parts-express.com/pe/pshowdetl.cfm?&DID=7&Partnumber=297-460&ctab=2#Tabs
Jul 02, 2009 | Sunfire True Sub MK II Subwoofer
60 HZ hum
Rita's Vintage Audio Repair is a Bob Carver Company & can repairs & updates Subs at a reasonable cost try calling them.
May 05, 2009 | Sunfire True Sub MK II Subwoofer
Sunfire True Sub MK II Subwoofer Logo
446 people viewed this question
Top Sunfire Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
