SOURCE: pioneer deh-2000r wiring
Pioneer usually use:
red - 12 volt batt. ignition/acc
yellow - 12 volt batt. memory
black - ground
blue - power ant.
blue/white - amp turn on
orange - illumination ( 12 volt light ) ( not all deck )
orange/white - dimmer ( not all deck )
gray - right front +
gray/black - right front -
white - left front +
white/black - left front -
violet - right rear +
violet/black - right rear -
green - left rear +
green/black - left rear -
Is this what your looking for?
SOURCE: pioneer deh-p6800mp wiring
You can find the wiring diagram online in a PDF of the installation manual, which is at this location
Hope that helps!
SOURCE: need wiring diagram for pioneer deh-p4000ub
http://akamaipix.crutchfield.com/Manuals/130/130DEHP4UB.PDF
Here is the PDF file for your radio. On page 63 is the start of the wiring diagram. I hope this helps. Please Rate this solution
Press FUNCTION to select the time.
Press FUNCTION until the time appears in the
display.
2 Select the portion of the time display you
wish to set with 2/3.
Pressing 2/3 will select a portion of the clock
display:
HOUR-MINUTE
As you select portions of the clock display the
portion selected will blink.
3 Select the correct time with 5/?.
Pressing 5 will increase the selected hour or
minute. Pressing ? will decrease the selected
hour or minute.
http://www.generalmanual.com/Players/Pioneer-DEH-P4400-Single-CD-Player.htm
