The code page says H4 indicates multiple errors have occurred. This generated a "safety fault rendering the lift unusable and a fault code of H4. The code sheet simply advise to contact the authorized Acorn dealer for support. My guess is this is a minor problem simply due to some unknown procedural step not being taken and is likely readily addressed. I suspect something equivalent to a system reset will have to be performed. You could try turning the power switch located on the stair life for 30 seconds, then turning it back on for a reset. This might clear the error and return functioning. It is equivalent to pulling the power plug. Here is a YouTube about changing the batteries. Possibly the unknown step might be mentioned in the YouTube: https://www.youtube.com/watch?v=dEDq3qpPbZ0
H4-00 generally means low temperature of the fuser. Check heater lamp, thermistor touching fuser drum surface, contacts and connections. It can be an electronic module failure, can require repair/exchange.
Not answer my question is what is the solution for wall mounted unit Model number 18cith1 has error H4 this error meaning here mention system protection.
This error is displayed when the Fixing heater has not reached normal operating temperature after a specified time. It is usually a blown heater element.
-H4-21 means:Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.) -Causes: Sub heater thermistor defect Sub heater lamp failure Sub thermostat failure Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2. When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit. When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch. Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*" Type in 1 4 Press start hit 1 for yes hit start
Unit should power off and the restart. If the error code recurrs ther are other problems.
