Panasonic LUMIX DMC-FZ38  (DMC-FZ35K) Digital Camera Logo
Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Suddenly we can't connect to our Mac. It worked fine before, but all of a sudden it's stopped. restarted the computer checked the connections, but nothing. it's just stuck.
Anonymous
Level 3:
  • Master 747 Answers
  • Posted on Mar 04, 2011
Anonymous
Master
Level 3:
Answers
747
Questions
0
Helped
177272
Points
2087
As a Mac user I don't bother with the camera software nor do I download using the camera. Best way to work around the software and firmware incompatibilities is to purchase a memory card reader. The Mac looks at this as an external drive and you can open the memory card see the thumbnails copy and paste the files into a folder in "Documents". Don't know what OS you have but there is a viewer that you can open to see the pictures and if you were successful in loading the camera software you can use it to do your photo editing. My suggestion would be to invest in a Photoshop program. The reason I'm suggesting this is Photoshop is the "industry" standard and by having a multiple port card reader you can change cameras, even memory card types without the hassle of programming compatibilities. Now as far as this "all of a sudden it stopped" what has happened is there was an auto update which basically made the camera download non compatible.
I don't know how old your Panasonic is but there is a lot of people still using "older" digital cameras that work just fine but the computer updates and software is leaving them in the dark. The Mac will work great with the card reader (I'm using Photoshop CS3) and a Photoshop program even if you update the OS. People that are using PC and upgrade to Windows 7 are just dead in the water when it come to the camera software. Oh and another thing that's happening is memory card capacity at one time a 2gig was huge and the camera firmware was compatible with 2gig memory but, if you try putting a larger memory card in say a 4gig the camera won't accept it. I was fortunate with a couple of my Pro cameras where I was able to go onto the manufactures web site and update my cameras. Cheers have a great day ;-)
Toshiba Qosmio x875 keyboard suddenly stops working
pls remove the key board ribbon cable and re seat again
Suddenly stopped working ,won't restart my PC?
First of all disconnect all peropheral connected to your motherboard. Take out Your RAM and clean it with soft clothe. Reinsert ram and restart your PC. If you can get display at this point then shut down your PC connect all peripheral back and restart your PC.
If not you will need to replace your ram.
1helpful
Suddenly, my 500GB Seagate external hard drive couldn't mount on my iMac. It was working fine till yesterday. I connected them to the Mac USD port, and the light in the seagate is blinking... Any
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
2helpful
I have brother MFC-7420 printer which was working fine on my mac pc, now all of a sudden it has stopped printing or scanning and says printer offline
Try a new data cable. Make sure there are no error messages on the printer itself and that it is on.
If you are using a USB hub or print server, try a direct connection. Check that a known working device works in the ports. Try uninstalling the driver and reinstalling it. The drivers are available here: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc7420_all . Select your OS, then language and click Search.
Check the device status and the USB status. (I know how to do this in Windows but forget the Mac specifics.)
I hope this helps.
(we recently had a Windows computer that suddenly wouldn't correctly identify any device on the USB ports. On that laptop, we had to pull the battery and disconnect the charger to clear the USB error.)
2answers
Suddenly stops showing the picture
The cause is a sudden overheat but when restarted its fine then it goes again this intermittant issue is with the lamp beleave that or not i found replacing the lamp solved the issue perm.
Thanks and please leave postive feedback..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Left mouse button all of the sudden stopped working
check all connections and restart computer. The p.o.s.t. will sometimes correct the problem. if not inspect the mouse physically and be sure all is well. It could be a switch inside the mouse if so simply take it apart carefully and check.if you have another mouse try it and see if it works this will let you know if it is your mouse or your computer. To test the bad mouse use it on another computer and see if it operates there.
I have an inspiron laptop. the two USB on the side stopped working all of a sudden however when I checked the computer stated that they are working fine
may i know what device was connected to those ports?try connecting a mouse to the same ports and see whether it is detected.If it works well and fine.Other wise goto Control panel>>System>>Device manager>>Universal Serial Bus Controllers>>Here, delete all the USB Root hubs.If you are removing them using a mouse connected,then u might lose the mouse response after u delete the USB Root hubs.Please note this.Restart the system after deleting all the Root hubs and wait for a few seconds for them to get installed back.Restart again and confirm whether the issue is resolved
Only test pages print perfectly!!
If when you print a test page it comes out perfectly, that means that the printer works, and the problem is communication between the printer and Mac.
Try the following:
Start testing a different USB cable and a different port.
Unplug Mac, and eventually remove the battery.
Unplug the printer power cable and USB.
Put the mac back toghether and restart it with printer usb not connected.
When mac is on, reinstall printer software driver, with Mac still not connected to printer, using printer disk or download.
Connect printer to Mac when asked by software.
If that still does not work, test the printer on a different computer, even if it is not common, the printer may have a faulty USB port.
Scanner suddenly disappeared from the Applications folders.
First unplug scanner, turn off mac, remove mac battery and unplug adapter, plug everything back , restart and reconnect.
If that did not work, then do the following:
Unplug scanner usb and reinstall scanner/printer software again on your MAC.
Computer stopped recognizing the speakers
You need to reinstall the latest drivers for your present sound device then restart your pc then check it. It will work surely! you should install the drivers that came with your sound devices! thats it!
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
