These are symptoms of a broken door lock and switch assembly and the only viable solution is replacing the said assembly if no issue is found with the wire harness connections. The machine will not advance to the spin cycle unless the door lock spin switch is activated. This is a safety feature to prevent the door from opening and avoid injuries during the high-speed cycle. Replace the door lock and switch assembly and it should solve the problem. Click on the link below for the detailed instruictions on how to replace the door lock and switch assembly. The part number for the door lock and switch assembly of your machine may be different but the instructions still apply.
Replacing the Door Lock and Switch Assembly on Kenmore Front-Load Washing Machines
