From this problem's description I have to assume that either the blu ray player will not play blu rays or the blu ray player will play blu rays but only in 1080i/720p or that you want to know if this blu ray player supports the 1080p resolution.
If the blu ray player is not playing blu rays then you update the firmware and try multiple purchased discs to make sure nothing is wrong with the ones you have been trying. If blu rays that played once will no longer play, then you will need to reset the blu ray player from its menu and possibly by holding down the power button on the front of the unit until the word reset displays on the unit before trying to play the disc again.
If the television is not showing 1080p make sure you are connected with an hdmi cable and that it is the right version hdmi cable for this blu ray player and for your television. Make sure you have chosen 1080p as the resolution to display in the blu ray player's menu. If all of that has been done and 1080p will still not display then it is a case of incompatibility between manufacturers--Sharp and whatever the television is. It would display in 1080p on a Sharp television and most likely on a Samsung and Sony as well. With other brands and even some models of the aforementioned brands (except for Sharp) its a toss up.
It's not an issue of the resolution.
There are several reasons why that might be so. If you buy a DVD or Blu-ray Disc that is either a video or movie disc, one important thing you should note is that some of them are locked to particular regions which means they can only play on devices to which they are assigned to. For example, you can only play a Region A Blu-ray Disc on a Region A device or console. As with discs, it is also important to note that devices may also be locked to particular regions. This is especially the case when the device is older (like the Play Station 2 or 3), but newer systems and consoles (like the Play Station 4 and Xbox One) are mostly region free. Here is some more information about regions for DVD and Blu-ray Discs:
Check the following post for possible solutions.
https://www.leawo.org/entips/dvd-wont-play-on-game-console-1373.html?fixya=1410
You can try Leawo Blu-ray Player which is a 1080p player and a 4K player. This free Blu-ray player can enable you to play any Blu-ray discs and DVD discs from any regions.
Try this one, not so expensive. It can support any media format that you can possibly think of, video, audio, even photos. Also, this brilliant Blu-ray player now supports Blu-ray menu and DVD menu, which make it really convenient to play movies and choose settings.http://download.cnet.com/Macgo-Mac-Blu-ray-Player/3000-13632_4-75453324.html
