1. In Outlook 2007, click the Tools menu and select Options.
2. In the Options dialog box, click the Mail Setup tab and then click the Data Files button.
3. In the Account settings window, you will see all of your personal Outlook data files listed. Here, you want to note the full path to each data file. On my system, my Outlook personal and archive folders are stored in the C:\Documents and Settings\Your Username\Local Settings\Application Data\Microsoft\Outlook folder.
4. Once you have this information, close the Account Settings dialog box and then close the Outlook Options window.
Now that you have the location of your Outlook data files, you need to check and repair them using the Microsoft Office Outlook 2007 Inbox Repair Tool-SCANPST.exe. By default, you should see SCANPST.exe in the Microsoft Office installation folder's "Office 12" subfolder. On my system, SCANPST.exe is located in C:\Program Files\Microsoft Office\Office 12. For additional information on SCANPST.exe, take a look at the Microsoft Knowledge Base article, "How to use the Inbox Repair Tools to recover e-mail messages in Outlook 2002 and Outlook 2003."
To check and repair your Outlook data files, follow these steps:
1. First, close Outlook 2007.
2. Use Windows Explorer to browse to SCANPST.exe, then double-click it.
3. When the Outlook 2007 Inbox Repair Tool opens, click Browse and navigate to the Outlook data file location that you found earlier. Note that you will need to check each file listed. On my system, I start with the file archive.pst. To check that file, you would select it in the "Select File to Scan" dialog box and then click Open.
4. Now click Start to begin the repair process.
