Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony KDL-32V2500 : It comes on and after few seconds the red light blinks 4 times, then stops and then starts blinking all over again.
  • 963 Answers
This is sort of a generic answer but I found this info about Sony blink codes. Hope it helps!
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Posted on Mar 05, 2011
    Scholar:
  • 88 Answers
Foot note to the Sony blink codes that I learned the hard way. Different models have different blink codes. Don't do like I did and bust your rear thinking one code fits all. Download the codes for the model you have.
Gillight
Posted on Oct 23, 2012
    New Friend:
  • 11 Answers
I have the same problem wit my kdl-32V4200. In my case I have changed the inverter the power board and now I am waiting for a main board. Also I had opened the lcd and seen the lamps are on for a second or two. THE SAME SYMPTOMS 4 RED BLINKS.
now you can test the inverter with an multimeter( the terminals after the transformers can be tested in OHMS) you should have the same reading an all 5.
Posted on Jul 18, 2013
6ya staff
SOURCE:
Hi I ve a sony KDL-40W2000 stuck on stdby red light flashing 4 times the stop for 3 second ??any advice please
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 16, 2014 | Televison & Video
Sony KDL-52w5500 black screen 13 blink then 14 blink
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
Mar 21, 2014 | Sony KDL-32M3000 32 in. LCD Television
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
Has verticle lines and turns off.
SONY LCD TV 32 inch, Display problems. Display half white colour.
Jan 20, 2012 | Sony KDL-32M3000 32 in. LCD Television
Sony kdl-32v2500 with selfdiagnose 4 times blinking. Possible blacklight inverter broken. how to change; where is location from the inverter
Back light inverter is mounted on left side of lcd panel if you see it rear and subject board would be covered with some shield. Remove screws of shield and circuit board, unplug connectors and take it out. Put new board, plug connectors, tight screws.
Jun 23, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony kdl-40s2000 won't stay on and blink red 4 times
That error says backlight failure. It has to be troubleshooted to find out why.
Apr 20, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony wega kdsr60xbr1 blinks red 4 times
Probably the power supply is failing
Dec 21, 2017 | Sony Televison & Video
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
1,384 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
