Microsoft Windows XP Professional Logo
Posted on Jul 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microsoft Window XP
I'm using MS Win-XP OS in my Home PC. Since few days I get an alert "..can not read boot.vbs. file.." and booting becomes delayed. While shuting down, I get the same problem. Some of the operations become incompelete/incorrect because of this. I tried to repair by using the OS disk but failed to get any solution. Please advise.
Anonymous
Level 2:
Sergeant:
  • Expert 260 Answers
  • Posted on Jul 30, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
260
Questions
0
Helped
67707
Points
624
Your problem is in the virtual basic script. That is the language that Windows has supported since Win 98 came out. It is most helpful on internet explorer. Somehow your boot file has been corrupted. There is a way to edit this in your registry through Regedit, but you need to be very familiar with the Registry before attempting that alone. I recommend finding a virus protection software package to help you debug your computer.
CH
My laptop running in win xp home edition sp3 does not boot. it only shows the options to run in safe mode, etc...Last known good configuration... how do i solve this? it doesnt boot.
Try to buy a Windows XP2 cd . The cd key is ( HH8M2 - JV8XT - PGWY2 - 8WV28 - 2B9M3 ). Replace your old OS xp home edition , with Windows XP2 OS. Hoping this would solve your problem sir. Have a nice day..
2answers
I turned on the PC, was asked to choose between WIN and WIN XP. When I choose WIN XP, the message comes up that "file nvrd32.sys could not be found" and so then I had to reboot the PC, choose WIN...
need the xp disc someone or thing has deleted a system-32, made the same mistake and had to reload the OS. System 32 is a main part of Your OS with just one little whoops of deletion you render the program useless. it should save your old stuff in a win.old file which it'll explain as you redo the whole thing over again good luck hope I can help
I use hp nx9010, i want to re-install windows xp but any time i try, the machine shutdown. sometimes is able to move up to copping files sometimes not then shutdown; i don't understand why is only windows...
well that is so easy to answer,
first off you are not using real HP disks are you.
sure. its old Blue Microsoft disks right,
and when you do that wrong, you get no HP chip drivers and lost more missing, even top row, fn keys dead, not just audio.
XP is a dead OS. for 3 years now, zero updates and is now a virus magnet extream.
nx9010 note book shuts down, all 3 os install different. !
old XP runs a very old and very DUMBB seteup.,exe
the newer OS run WINPE for setup.exe. vastly better and boots and loads the OS totally different.
Xp can be installed many ways, not one stated by you.
1-insert, HP install disk in CDROM drive and click, setup.exe running in a XP explorer window, live install
2: boot to HP install disk.
3: boot and hit F11 run HPs on HDD restore partition.
4: same as a above 1, or 2, but is Micro soft disk (wrong, you did it wrong, do not use mS disk) if must ask how, its a long long long story. ive done it all ways, 1000s of time. now since first PC.s ever.
if booting to XP , right or wrong CD. (its a CD right<)> or a stick
that too not stated,
it boots and you answer questions, then it starts copying
if it stalls that means, the CD is bad.
or PC is bad, you do know there are 3million transistors here to fail right? bad HDD, bad Mobo, and more. lots more
even the CPU can over heat and will shut down.
Personally I avoid all CD nows, they sux'd then and do now more.
make and ISO of your CD, (ask its easy and free)
then burn the ISO to a 4GB or bigger uSB memory stick using free RUFUS app.
boot to stick. on my HP hit F9 and pick Udisk USB. boot
bingo no more CD errors ever again.
i bet bad CD. seen it vast times, endless , but not today. too savvy now. to mess with any CD, if you copy it to ISO and get CRC errors
its a bad CD.
end pain.
the problem with real old PC most cant boot to USB
or must be BIOS flashed updated to get that.
ill now ill try to learn what yours can or can not do.
lacking ,what is there now.
but id do this first. go in to BIOS BOOT PAGE
What is the default boot order? The default boot order settings for the computer are configured in the factory. The default boot order for HP notebook PCs is listed below.
  1. Floppy disk drive
  2. Optical drive (DVD, CD-ROM)
  3. Hard drive
  4. USB device (see this?) bingo, can boot and install any OS here
  5. Network adapter
I have 2 HDD's in my PC - both with Win XP Prop
Boot.ini is correct, but looks default is booting from Disk2 and partition 1 which is your G:\ 500 GB.
Try Copying boot.ini from c:\boot.ini to g:\boot.ini It might help
In your example I see missing "\" after partition(1), may be typing mistake, but in real time can generate error.
You boot.ini looks exactly same in both drive c:\ & G:\
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(2)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="GUY DRIVE XP Professional" /noexecute=optin /fastdetect
Note: boot.ini will be hidden and readonly file. You need to unhide the file and remote the read only option and then only you will be able to save the boot.ini file
Hope this helps
My laptop is in a boot loop, boots up and turns off before loading the os. I have the key sticker on the back but cannot read the os version.. I know it is Vista home but don't know if it is basic or...
windows boot files are corrupt...
it may not make any difference...as youhave to re-install the OS again....
but if you have the recovery CD that came with the noetebook then try use that CD to recover the OS
or
if you have the original WinVista CD then try do a repair of the OS
if all these fail then i am sorry only a reinstal;l of OS can solve the issue....
visit my site for more details on installling Win OS(XP)
installling Win Vista is similar
www.sureshayyar.110mb.com
1helpful
On startup cannot find script file 'cleanvirus.vbs'
May be you affected with a virus or missing some files...try to restore go to start /Accessories/System tools/System restore...try it
Loading win xp gives message script file cleanvirus.vbs not found
Disable System Restore. Scan your computer with the free version of Malwarebytes' Anti-Malware.
http://malwarebytes.org/
If you don't have an Anti-Virus program, download Avast and scan.
http://www.avast.com/
If both scans don't detect anything, do this..
Ctrl-Alt-Del > Processes - End the following processes in order:
dxdlg.exe
wscript.exe
Start > Run > regedit - Open the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\ Microsoft\Windows NT\CurrentVersion\Winlogon
In the right hand pane, select Userinit and delete everything except C:\windows\system32\ userinit.exe
Make sure the processes wscript.exe and dxdlg.exe are not running.
Delete the following files
C:\Windows\System32\dxdlg.exe
C:\Windows\System32\boot.vbs
In your Windows drive, search for boot.vbs and delete all of them.
In your Windows drive, search for kinza.exe and delete all of them.
Enable System Restore.
Restart your computer.
I have installed Ubantu in my aspire 5050. Now I want to install win XP so that I can open MS Office from Linux
do you want to make a dual-boot system? you must have installed windows OS first and leave a non-partitioned drive in your hard Disk. Then you can install Ubuntu next, instaling it to the non-partitioned drive. When the PC boots, you will be prompted to what OS to boot.
Anyway, you can Install Windows XP in any free Drive. But it is dangerous since Windows Installer might destroy your Ubuntu installation files.
XP RESTARTS
this is caused because a file of your pc has become corrupt and your XP needs to be reinstalled.
1helpful
3answers
Win XP problem while starting
hi
go to the recovery console and run chkdsk utility. if your problem still remain and if u have win xp setup source then repair your os.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
