This article will give you the Safest, Easiest and Quickest way to Fix the YLOD, Red Light of Death.
In order to fix the YLOD, RLOD error on your PS3, you should try the following 3 things:
1 - Restart your console.
2 - Take out all cables, and plug them back in.
3 - Take out the hard-drive, and place it back in your PS3 console.
If these 3 tips didn't help you to fix your PS3 red light error, then it's high likely that you need to open up your console, and fix the problem from within. I really can't help you with that, because you'll need step by step instructions that's coming along with either videos or pictures. But, you've got 3 options to get your hardware problems solved.
There Are 3 Ways To Fix Your PS3 Red Light Problems.
1) If you have no idea of to fix the PS3 yourself, you could send your PS3 back to Sony and let them figure out how to repair the problem. This can take some time and unfortunately if your warranty has expired you will be paying around $150.
2) Take your PS3 to your local repair shop and let them fix it. The downside to this is that they can't guarantee that your PS3 will be fixed.
3) Fix your PlayStation 3 by yourself. If you don't know how to fix ps3 flashing red light, then it's no problem. It's not hard or expensive, and I was lucky to stumble across this site that sorted me out in no time.
To fix your PlayStation 3 by yourself, I'd recommend that you take a look at PS3LIGHTSFIX This is a step by step guide with detailed instructions and pictures how to fix your PS3 problems. It also contains bonuses for after your reparation.
I hope this will be of help to you as it was to me!
Does the lights blink red? If so, You have the infamous YLOD, aka. Yellow Light of Death. (now it comes back on, eventually it won't) This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself as some would suggest.You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
I want to just make it clear to you, that you can repair the
following problems at home with a good repair guide. There is no technical
knowledge needed you simply do what you see on the step by step videos or the
paper guide.
The best thing is to get and keep your PS3 guide for life so if
something goes wrong in the future you can just review your guide and fix it.
click here to download ps3 repair guide
