The function setting is for the PANEL sustain (Page 68 of your manual)
The other method of sustain is by footswitch or pedal option. See page 13.
If you use a footswitch, it needs to be a normally open contact type. If you plug a Roland type in, it is opposite polarity and will sustain UNLESS the pedal is pressed. Make sure nothing else is plugged in the sustain jack... headphones that are inadvertently plugged in there would sustain.
Hi ,Thanks for the guidance.I have checked the panel sustain and it is showing "off" in the function . The sustain happens now even without the sustain pedal being plugged. can you pls guide me how to get back to normal mode if i guess if a polarity change has happened due to any false operation during my previous play.
Normally this keyboard reads the state of the pedal at power up to determine if it is a normally open or closed.. Try powering up with the pedal pressed to see if it reverses the state.
If this doesn't work, find the "factory reset" procedure and do that. I don't think there is anything you can do during play to cause this. HOWEVER, if you have recorded/saved a song, the state of the pedal MAY be stored with the song and will come back whenever you load or play the song.
Thanks, can you pls tell me where i can get the factory reset procedure ,since i have tried duing power on by holding the highest white key to restore the setting.
Two things. You can also clear the files by holding the top white and the three top black keys down when turning on the power. The highest white key should reset the main stuff.
PLEASE NOTE: You typically need to hold the key(s) down until the display indicates the function has been performed. This can take a bit of time.
