The easiest way to check for broken engine mount is to put one foot on the brake and push the throttle to watch the engine move. the mounts are located on the bottom of the engine
about where the transmission and engine are bolted together. Make sure that you test in foward and reverse,because they might both be broken. `Engine oil leaks on the rubber mounts and softens the rubber on the mounts makes the go bad . Also hard acceleration is hard on the mounts
I think Ihave a broken motor mount
