With a timer like that , start here. Unplg it and have it in your hand. Pull up all the tabs. Push down the tabs from 7pm-6am. Now, find in the center ot the unit, the little arrow, turn till the correct time, the the right now is at the arrow. Plug in right away. As for the timer switch, timer on will work just as timer, push to outlet on will turn the lamp on manually. Also keep in mind that if the power goes you will have to realign the arrow with the actual time.
You can get the manual on the link below to set the timer. If that is not your timer then go to the second link and find your timer to get the manual. also on the bottom is a picture how to set the pins.
http://waterheatertimer.org/pdf/Woods-59200.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html
SOURCE: I have set
Woods 7-day timer:
Timer dial is supposed to rotate at all times no matter if override switch is set set to ON or Timer.
Sounds like the timer is broken.
SOURCE: Instructions to set Woods indoor timer 59377
Open following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
To set current time, press and hold clock button while pushing hour and minute buttons.
Then release clock button
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
