Electrolux 504199 Dishwasher Logo
Posted on Mar 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wt65h showing error code c8 How do I reset the machine?
Anonymous
Level 3:
  • Electrolux Master 1,902 Answers
  • Posted on Mar 06, 2011
Anonymous
Electrolux Master
Level 3:
Answers
1902
Questions
0
Helped
533434
Points
5669
Hello & Welcome to FixYa
To reset the unit you can leave it unplugged for 15 minutes as there is no other way for reset. C8 error means that the unit is unable to drain properly/completely and you can take off the bottom access panel to clean it completely. If the problem returns then the drain pump needs replacement. Please get back to me if you have any other questions.
Kevin
1 Related Answer
W.L.
  • 2511 Answers
SOURCE: Electrolux dishwasher wt65h shoing
If there is a set button hold it in for 5 secs!
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Sir ricoh printer is not working in red light and display in c8 whats problem now tell me
Fusing Reload Temperature Error (Fatal Error)
After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
There is a problem with the fuser section p/n M1014002 -Carl
IF THI IS A SP200
17helpful
2answers
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
5helpful
2answers
Model sp200s. What does c8 error indicate?
Show my printer on display C8 on Ricoh SP 100Su
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
DISHWASHWER WT 65 EIM:ERROR CODE C8.WHAT DOES IT MEAN?
according to the manual...error code 8 indicates a problem with the control panel. here is the link to this manual...page 21 of the pdf http://manuals.electroluxusa.com/prodinfo_pdf/Kinston/154671101en.pdf
Hope this helps you! PS, this model number in the link may or not be similar to yours I had a problem locating your exact machine..so let me know if it isn't the right one and I'll go look some more. meantime...is there another model number on the inside side of the washer door?
7helpful
2answers
How to solution of FUSER TEMP.
my rocoh printer SP 100su show on lcd panal C8 error code . power on .
5helpful
Electrolux wt55 error code c8
If there is a set button hold it for 5 seconds.
C8 means that at the rinse phase the boiler did not empty.
The reasons are ..
1) the nozzles are blockled
2)Drain pump out of order
now you must reset c8 from the parameter in order to start again the dishwasher
May 05, 2011 • Dishwashers
1helpful
2answers
Electrolux dishwasher wt65h shoing error code c8. How do I reset? Another posting said to reset from the parameter? can someone explain?
What exactly is the error code c8
I think error code C8 is #13
Check following links to see if they have information:
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Manual shows error 05 or 13:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
1helpful
New Richmond tankless water heater C8 error
It has to do with air quality, lack of sufficient air, or lack of venting or dirty air filter.
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
