If you want to use a computer to read the internal memory or the SD card in the Panasonic Lumix DMC-ZS5, you will need the correct USB cable, which is an 8-pin micro USB (M) to USB A cable, . (One example:
https://www.amazon.com/dCables-Panasonic-Lumix-DMC-ZS5-Cable/dp/B00448MAWK ) Then ensure that the camera is fully charged or is getting additional power (AC adapter or DC coupler). After connecting the camera to the computer, you should be able to transfer files from File Explorer (Windows) or the Desktop (Mac). This may depend on your OS, see page 140 of the Advanced Features Manual for the supported OS versions. (Check Windows compatibility for later Windows version compatibility.)
With Windows XP, Vista or 7, you can also use the PhotoFunStudio that came on the CD with the camera. There is an update to the software here:
http://av.jpn.support.panasonic.com/support/global/cs/soft/download/pfs50.html . See the manual for using the PhotoFunStudio software.
The direct link to the Advanced Feature manual is
ftp://ftp.panasonic.com/camera/om/dmc-zs7_adv_en_om.pdf .
I hope this helps.
