"AP" stands for Agitation in Process", it appears in the copy quantity display when toner is being replenished inside of the copier. Wait a few minutes..this happens after continuously copying for long periods, or copying dense things like photos. Sometimes it will occur after running the machine when it is out of toner. replace toner and turn on/off a few times to "agitate toner. Don't worry about the scan lamp being lit while this is happening, it will go out.
Hope this helps
Hi The AP message indicates thet the dev is so low in toner that the machine has to go into a full cycle mode to get the toner levels up. The error code is telling you that one cycle is not enough. you will have to turn the copier off/on and cycle it at least one more time....more if neccessary
AP means that the copier is going thru a major toner cycle. Sometimes when you drag a lot of toner out for dark copies, the normal toner cycle is not enough. The spring that takes the toner from the cartridge to the dev unit mat also be faulty or broken. Sometimes the AP message will go away but make sure you have plenty of toner.
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
