I damaged my C140 camera socket probably by trying to put the wrong plug in, most likely too expensive to repair so be careful.
Your camera requires a "U8" type USB cable to connect between the standard USB port on your computer and the U8 jack on the camera.
A "U8" style USB cable & jack.
The U8 USB is similar in appearance to the USB "Mini" or USB "A" style jack. But will not mate to any other jack besides the U8 style. A typical USB Mini or "A" is shown below for comparison.
The camera shipped with the correct cable, but you probably didn;t notice there was a difference between it and other USB Mini cables - and simply grabbed the wrong one.
I hope this helps & good luck! Please rate my reply - thank you.
Here's where you plug it in: http://tinyurl.com/6y3f88b
The USB cable plugs in right underneath where the memory card goes.
http://img.ps2netdrivers.net/img/a4/kodak.c643/big.jpg
For this type of mini USB connection, you need the correct type of cable.
It looks like this:
http://www.onlineshop.com.sg/images/HTC90AUS001-01.jpg
These cables are very common, and not too expensive.
I would suggest taking the camera with you to a computer store, of FutureShop etc and tell them you need a mini USB cable for your camera.
While facing the front of the camera, there is a little door on the right side. The USB slot or port is inside the door at the bottom.
