Question about Whirlpool Duet GHW9150P Front Load Washer
Clothes don't spin dry enough
Hi
I have a Whirlpool Duet front load washer and lately the spin cycle does not get the clothes very dry. They come out only about as dry as they'd get if you hand wrung them lightly. The washer does spin but I don't know if it's not long enough or some other problem.
  • mlefevre Aug 08, 2008
    I can't tell if the washer spins fast enough or long enough. How would I know that? All I know is that when the washer says it's done, the clothes are not very dry. Running it through another spins cycle does get them a little drier, but not as dry as they used to get at the end of one spin cycle. The washer is 4 years old.
    Genius:
  • 1,665 Answers
Remove drain filter and ensure is clean. If it is clean and problem remains inspect also drain pump imeller to be clean.after i hope clothes drying problem will be resolved.
Posted on Aug 08, 2008
    Genius:
  • 1,847 Answers
Do you see it spining fast enough while it is drying mode?
Posted on Jul 31, 2008
    Guru:
  • 1,894 Answers
You mean to say the clothes are tangled with each other tightly right?
  • dewan nafees ahmed Jul 31, 2008
    To prevent your clothes from getting all tangled and knotted, you want to
    avoid combining heavy clothes with light clothes, don't make the load
    too big or too small, use the proper water levels for the load sizes,
    don't wrap any items around the agitator, and make sure that the wash
    water isn't too hot.
  • 3,037 Answers
Is the heating element working, have you tested it or noticed whether your clothes are coming out warm. It may have gone bad and needs replacing. Let me know if you have questions with this or need a place to buy the part. There are many online sites that will sell you a new element
my best to you
  • Benjamin Patri
    Benjamin Patri Aug 08, 2008
    I am so sorry, I totally thought it was a dryer, I must be getting tired.
    Is there any water left in the machine when it is done? How long does it stay in the spin cycle.
6ya staff
SOURCE:
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Whirlpool front load washer (W-WFC7500VW1) was ran through the clean cycle. After this was preformed, the washer will not spin the clothes the dry. The washer will spin but never reaches the 'higher' spin...
I suggest going on the Whirlpool manufacturers website and check their forums for a similar problem. It could very well be something very easy to fix.
Jan 08, 2015 | Whirlpool Washing Machines
I have never been so unhappy with a washer as my Duet front loader. It SMELLS horrible at times, spins and shakes violently. My clothes are always in knots, especially the sheets. My first Whirlpool and...
We had problems with ours shaking but it wasn't completely level.. But I use the clean washer cycle that uses bleach only and it works pretty good. Other than that, I don't have a clue..
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer knocking noise when in spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet front load whirlpool washer, I bought it about maybe 8-10 years ago. I'm start to get a error code when I wash on a 28 min cycle spin. The error is 5BR or 56R, it will stop spinning in the...
Hi these are not common codes for a duet. Click HERE for a list of common codes and corrective actions needed.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
THE WHIRLPOOL DUET WILL SHAKE YOUR HOUSE APART DURING THE SPIN DRY CYCLE. WHAT CAN I DO?
Adjust your washer's front legs and lock the nut, it has another nut to do this. After you hav locked the legs, try to rock the washer with your hands, it should not rock. Another thing to check will be inside your washer, after taking the power off the wall socket. Check to see if some springs or the shocks (dampers) have come loose. This normally happens when the load is not even, that is when you hav a big sheet in one part of the washer tub. Spread out the clothes evenly before you commence the wash.
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
668 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
