Hey! sorry but you will need to enter that appleID password to reactive the iPad. If you still have the original receipt you can call apple and have them start the recovery process.
Turn the unit off. Press and hold both the power button and the volume button at the same time, until the little yellow-green android robot comes on the screen. You can then release the buttons. You will eventually get a menu (this took a while to come up). Use the Volume button to scroll down to "Reset to Factory Standards", and select by pressing the power button.
please follow the following instructions i hope this helps
Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning
You need to press the Function button, then the num lock button. The function button may be labeled FN or F in a different color, the same color as the num lock button.
If that doesn't work, go to start, all programs, accessories, accesibility, on screen keyboard....it will display a regular keyboard on your screen, then click on the num lock key on that keyboard.
