Most major manufacturers supply manuals
online so if you were to log on to the manufacturer's web site, you
may be pleasantly surprised as usually, if available, one is able to
download, by model number, Customer
Instruction Manuals, Dealer
Network for spare part supplies as
required. The information is normally free of
charge. I hope this helps.
Goodmans ld2357d displays code when is turned on
065 064 100 588 285 037 292 544 207 318 363 399 402 515 527 392 371 245 563 297 584 060 103 263 508 063 616 055
527
055
402
563
662
696
652
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies as required.
charge.
I hope this helps.
