Sony VAIO VGP-WKB1 Keyboard Logo
Posted on Mar 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keyboard is not working on new Vaio laptop. - Sony VAIO VGP-WKB1 Keyboard
Mike
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Sony Master 884 Answers
  • Posted on Mar 20, 2015
 Mike
Sony Master
Level 3:
Renaissance:
Answers
884
Questions
Helped
195235
Points
4435
Hi
I agree with Jason Nord for this, but if after a couple of times trying it, and since it is new don't do anything more that might invalidate your warranty but take it to the vendor and get him to sort out a replacement, as after these tries it is likely to be faulty and therefore not of Merchantable Quality.
Cheers
hanan
Level 1:
New Friend:
  • Contributor 1 Answer
hanan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
260
Points
How to use the wireless keyboard for the first time on tablet
Anonymous
Level 2:
  • Expert 104 Answers
  • Posted on Mar 08, 2011
Anonymous
Expert
Level 2:
Answers
104
Questions
0
Helped
53149
Points
355
Once you have checked the batteries in the keyboard, then push the tiny little button on the side of the computer around the peripheral plug ins. After pushing that, hit the connect button on the wireless device. They should be re-syncd.
If you still have trouble with the keyboard it may be defective.
Some letters don't work on my sony vaio
Check the keyboard. If it is defective replace it. You might want to hook up a USB keyboard to ascertain that the laptop keyboard is the one that is defective.
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
2answers
Function key doesnt work
The laptop keyboard will need to be replaced, go to www.ebay.com Type: make and model of laptop, refine search to keyboard.
I have a sony vaio vgn fs980 laptop. all of a sudden the keyboard stop working. i purchased a new keyboard. However the same problem exists. I can use an external keyboard that will work fine but the...
On every computer motherboard there is what's called a UART chip. This chip is responsible for capturing every keyboard click, interpreting what letter it is, converting it to zeros or ones used by computers, and sending it to the processor for action. If this chip fails, even replacing the keyboard won't fix it.
Unfortunately this chip is usually part of the motherboard so the only way to replace it is to replace the motherboard, which usually isn't cheap. If you can live with the external keyboard you might want to stay with that. Otherwise, if you Google sony Vaio motherboards, I'm sure you can find a number of sources online to purchase a motherboard. Replacing one is tricky but not insurmountable if you take your time and can follow directions, also available online.
Best of luck! Hope this helps!
I have sony vaio EB series laptop, my problem is that when I type 1 it type 21, when 3 it type 0.3, when 1 below f1 key it type 1 and open help window. there are other similar keys behaving same way. I got...
Hello
If the new keyboard is behaving same, then try to plug in an external keyboard to see if that works okay. You can use any USB keyboard. If this keyboard works, you have a hardware problem and need repair from Sony Support.
Hope this helps, Good Luck
Sony vaio laptop - some keys on keyboard does not work
you can use keyboard in the windows to replace keys dont work in your keyboard
go start-> program->accesoires->accesbility-> on screen keyboard.
or you have condition take to prepaire for change new keyboard
2helpful
2answers
FIfa 09 Keyboard Problem, When I press 2 directional buttons plus shoot, pass e.t.c it isn't working.
i have the same problem with fifa 10 Sony Vaio VPCEC1M1E when i play with other usb keyboard its working but with my laptop keyboard ist working..
Vodka lemon onto my sony vaio vgn-n38 laptop
call sony, 18887398246, have all your info ready that is on your laptop. order new keyboard.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
