SOURCE: blood pressure monitor problem
The two numbers that measure your blood pressure are written like a fraction: one number on top and one on the bottom. The top number in a blood pressure reading refers to the systolic pressure. It measures the pressure inside your blood vessels at the moment your heart beats. The bottom number represents your diastolic pressure. It measures the pressure in your blood vessels when your heart is resting between heartbeats. A good blood pressure for most people will be under 120/80, as most people with blood pressure problems have high blood pressure. However, extreme low blood pressure can also be a serious health concern.
SOURCE: mabis 04-206 blood pressure monitor getting err
what kind of error you getting from bp monitor please be clear and write in detail if not please feel free to call me +91-9884462250 Rehman
SOURCE: I have a wristech modelzsbp-002.Half way through
I'm not really sure what error i had with this type of blood monitor but i found that the problem was with the two little knobs behind, that were stick out too much . If you put your finger behind the blood monitor , in the area that comes in contact with the wrist, you should feel two little knobs under the textile material. If they stick out too much try to gently push them in. Hope this is work....
SOURCE: err 3 is displayed
Wrist blood pressure monitors must be used with the arm above heart level. You can do the pledge of allegiance while doing a reading to make sure this is done. Usually this error occurs when inflation takes too long or the placement of cuff is wrong.
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Testimonial: "Sound advice."
