While watching the tv the picture froze then went blank. I shut it down the tried turning it on after a while, but I get a hum and the lamp light blinks for a minute then stops. A bit later shuts down and the hum goes away. And the standby light comes back on.
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER915B403001
Lamp (180W)
3 times blink shows lamp cover is removed or not installed properly on TV. Please take out lamp inside TV and check, seems its broken as you heard loud pop. Thanks.
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Replace the lamp. In rare cases, the lamp power supply or lamp ballast may also need replacing. But, replace the lamp first, and use an original Sony lamp not a cheap aftermarket replacement. If this helps, please be sure to rate the fix! Thanks!
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
