Epson Stylus CX8300 Printer Logo
Posted on Mar 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you replace ink - Epson Stylus CX8300 Printer
Anonymous
Level 3:
  • Master 1,940 Answers
  • Posted on Mar 09, 2011
Anonymous
Master
Level 3:
Answers
1940
Questions
0
Helped
954226
Points
5951
  1. Lift the top panel to gain access to the Ink and holder.
  2. Release the ink from the holder and remove each ink cartridge.
  3. Install the new cartridges, carefully lining them up.
  4. Close the ink holder and close the top panel.
Here is the quick start guide, that has pictures to show how to change the cartridges: http://www.4shared.com/document/DCx8iZrQ/Epson_Stylus_CX8300_Start_Here.html
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Anonymous
Level 2:
Sergeant:
  • Expert 159 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
159
Questions
0
Helped
53582
Points
547
You may want to try the following link, its the manual showing how to replace ink.
http://support.epson.ru/products/manuals/100441/SCX8300_BOG_EN.pdf
I do hope this helps.
Best of luck!!
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
1681
Points
32
You can find complete instructions on what cartridges to order and how to install them at this link.
1helpful
NX200. How can I change the ink cartridges?
Replace Ink Cartridges - Epson
files.support.epson.com > NX200UG.1.100.html
Replace Ink Cartridges. Your Epson Stylus NX200 Series and its software will let you know when an ink cartridge is low or expended. If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
Manual
Replacing Ink Cartridges - Epson STYLUS NX200 Series ...www.manualslib.com > ... > Quick manualEpson STYLUS NX200 Series Manual Online: Replacing Ink Cartridges. Make sure you have a new ink cartridge before you begin. You must install new ...Local results
Videos as well
https://www.google.com/search?q=epson+nx200+ink+cartridge+replacement
.. Anything else Denise, just click COMMENT under my post.
I am getting the following error. 09,038,46:15008
09,038,46:15008
Ink count flag stuck after melting 2.5 Black Ink Sticks.
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
Troubleshooting Procedure
1 Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Are the Ink Sticks loading properly?
Yes) Go to Step 2.
No)Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. This must be performed following an ink loader replacement.
2 Test the appropriate Ink Melt Heater. Run the Service Diagnostics Ink Melt
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
4 = Black
Did the test pass?
Yes) Replace the Printhead
No)Replace the Ink Loader.
1helpful
ERROR 09,038,46:11950
Fault codes associated when ink count flags are stuck after melting 2.5 ink sticks.(Black ink)
1. Are the ink sticks all Xerox ink? Are they the correct ink sticks for the printer model?
Yes)Go to Step 2.
No)Advise customer. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
2. Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Yes)Go to Step 3.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu.
3.Run the appropriate Ink Melt [1, 2, 3, 4]
Heater test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Did the test pass?
Yes)Replace the printhead.
No) Replace the ink loader assembly. Run clear ISC fault test to clear the error. The clear ISC Fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
Could tell me what is the following code : 09,035.43:62287 on phaser 8560 mfp. please
Ink count flag stuck after melting 2.5 Cyan Ink Sticks.
Initial Actions
1. Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks. Are the Ink Sticks loading properly?
Yes)Go to Step 2.
2. Test the appropriate Ink Melt Heater.
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Yes)Replace the Printhead
2helpful
2answers
I have replaced black ink cartridge 73N message on screen says Error i press ok to proceed message goes back saying replace ink cartridge?
The main problem in using the latest Epson printers, is the ink replacements. Ink cartridges like 73N has its own ink reseter (the little chip in front of the cartridge). Once you replaced the ink without using the right procedures, for example you have a 10% remaining ink level on one of the cartridge, and you replaced it without using the setup menu and selecting the replace ink cartridge, even though the cartridge is new, the printer will read the replaced cartridge as a 10% ink level cartridge. When the remaining 10%, drops to 0%, your cartridge will read as an empty cartridge. The chip on the cartridge is registered as an empty cartridge.
-try to replace the ink reseter or try to clean the cartridge chip then put back the ink.
2helpful
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
1helpful
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
How do you remove the ink cartridges from Canon MP890?
  1. If replacing both ink tanks, remove and replace each one individually.
  2. Make sure the device is powered on.
  3. Lift the scan unit until it locks into place. When the machine is ON and the scan unit is lifted, the paper output tray automatically opens.
  4. Open the inner cover.
  5. Hold the tab and pull it forward to release the ink tank.
  6. Lift out the ink tank.
  7. Remove the new ink tank from its packaging.
  8. Hold the ink tank and remove the protective cap.
  9. Insert the ink tank into the empty slot on the print head.
  10. If you need to replace the other ink tank, repeat steps 4 to 8.
  11. Close the inner cover.
  12. Return the scan unit to its original position. The LCD displays a message asking if you replaced an ink tank.
  13. Press [<] to select <YES>.
  14. The LCD displays a message asking if you replaced the black ink tank.
  15. If you replaced the black ink tank, press [<]. If you did not, press [>].
  16. The LCD displays a message asking if you replaced the color ink tank.
  17. If you replaced the color ink tank, press [<]. If you did not, press [>].
  18. The ink counter is now reset.
  19. If additional ink tanks need to be replaced, replace them now.
2helpful
2answers
Canon multifunction printer
I believe that he is reffering to the waste ink tank where the cartriges stop to the right when not being used. There are two small foam pads over there.
I cleaned mine by opening lid and have carriage run to the left, then I reach in with a q-tip and press down repeatly until q-tips are almost clean. You will need a flashlight to see waht you are doing.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
