Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
Posted on Mar 10, 2011
I have a 42" Toshiba flat screen. It was a floor
Anonymous
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Mar 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
12422
Points
85
Electronics stores don't sell bases for TVs.
Each TV comes with one base, each base comes with a TV. The only way to get a replacement base would be to contact Toshiba and ask them directly for a replacement. For this to work, you'd need the model number of the tv. This can generally be found when you look at the back of the TV, it will have the label on a small sticker somewhere on the back.
Once you have the model number, try doing a quick search on Ebay. Someone may have an old base there that they no longer need, otherwise you're stuck with a wall mount or with contacting Toshiba.
42"toshiba screen crack up
It would be more cost effective to purchase a new set.
TV saya Toshiba Regza 32 " flat, suatu hari
Hallo,
Setahu saya , penggantian transistor pada model-model LCD atau plasma jarang di lakukan, karena beresiko kerusakan komponen yang lain. Jika memang mau melakukan penggantian part , sebaiknya di pastikan dulu kerusakan penyebab rusaknya transistor tsb. jika yakin tidak ada yang rusak, transistor seperti model apa yang kamu cari bisa di cari di internet.
Atau tulis no part nya , mungkin saya bisa bantu.
Terima kasih.
I can not get the base off
Follow the below instruction on how to the base off your Toshiba LCD TV;
  1. Turn off your Toshiba TV if it is on.
  2. Unplug your TV from the wall and any other devices (like DVD players or Blu-ray players) that it is connected to.
  3. Put a blanket, towel or some other kind of soft object down on the floor (if you have hardwood floors and not carpeting in your home).
  4. Set your Toshiba TV down onto the soft surface with the screen facing downward toward the floor.
  5. Use a flat-head screwdriver to remove the two large, plastic bolts on the rear of the TV stand's base. These bolts are holding the stand onto your Toshiba TV. Set the bolts aside.
  6. Use your hand to pull the base off of the Toshiba TV. You will now be able to set your TV completely on the ground. Put the base (as well as the accompanying bolts) aside for safe-keeping, in case you ever need to use them again.
I hope the above helps.
Good luck.
Help, Help Help, I have a Toshiba 32 " flat screen. I cannot remove the base, What is the secret???
there is a screw that you are missing pull back every plastic or rubber stopper a screw is under there somewhere
5helpful
I need a pedestal stand for my Toshiba 42RV530U. Do you know where I can get one?
Manufacturer Toshiba Part Number 75010935 Description BASE BASE ASSY, BASE
1helpful
2answers
Phillips 42 inch tv
Vendor nap.jpg Part Number 310430814621 Description Stand Base
Tritronics, Inc.
(800) 638-3328
call these guys and they should be able to locate it for you or at least tell you where to get one.
Toshiba 42
YOUR INTERNAL POWER SUPPLY HAS FAILED , CONTACT TOSHIBA CUSTOMER SERVICES WHO ARE TOTALY OUTSTANDING . WITOUT DOUBT THE BEST CUSTOMER SERVICES I HAVE EVER HAD TO DEAL WITH
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
