Drills Logo
Posted on Mar 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. I have a charger for 18v Dewalt Li-Ion (dc9130 120v 60hz) and I'd like to find a circuit diagram so I might be able to convert it to use with 240v 50hz. So I probably need the diagram for the 240v one as well to replace whatever needs it? I'm experienced in such shenanigans! Thanks.
Keith Brown
Level 3:
  • Master 604 Answers
  • Posted on Mar 10, 2011
Keith Brown
Master
Level 3:
Answers
604
Questions
Helped
152354
Points
1823
Most chargers will fuction on 240/50 hz, look closely at the writing on the charger, it may say. I have laptop chargers and have used the overseas with no problem, that being said, you might try contacting dewalt and asking them if you can do it. Like I said, it probably already will work without doing anything. i have seen some devices (amplifiers mostly) that have a switch on the bakc to switch voltage, ( I don't recall ever seeing a switch to change line frequecny though), hope this helps a bit
2helpful
Dewalt DC9096 18V High Capacity XRP Batteries. Which is the correct charger for DC9096 battery please?
Question edited for a lot more clarity. All questions need full 'make model (what it is)' please.
Question moved from Garden to make model category.
It is this one with wildly differing prices!
https://www.google.com/search?q=Dewalt+DC9096+charger
Can I buy a battery charger for a ozito drill
hi Terry.
you could try homebase.or ebay will have them.
or this link should show you where you can buy them.
battery charger for ozito drill Google Search
Dec 02, 2017 • Drills
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
Dewalt DCB105 li-ion XR Battery Charger 10.8V - 20V
For Battery Type: Ni-Cd Ni-MH
Input Voltage: 110V-240V
Smart Charger for Dewalt 10.8V ~ 20V Li-ion Battery
For Brand: DEWALT
Color: Black
Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
http://www.drillbattery.com.au/charger/dewalt-DCB105-charger.html
1helpful
Can I use the charger with the 220 in UK ?
Unless it is rated for 220-50/110-60, you will need the converter. Besides the 110V US plugs won't plug into the 200V UK outlets.
2answers
Will dc24sa charg a 14.4 battery
I have a 12v an 18v Dewalt I can charge them both from the same charger
3helpful
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
2answers
I have 2 DeWalt Lithium-ion batteries Apprx. 4 years old, charged 3 times...won't charge now
Either bad batteries or a bad charger. You can use a multimeter to test for DC voltage output in the charger.
5helpful
5answers
Broken dewalt battery 18v lithium ion 2.0ah flashes fast red when in charger
When a Dewalt charger is showing a fast blinking red light it means the battery is no longer chargeable. It may be because of a bad cell or short inside the battery. Whatever the reason the charger will not charge the battery and it needs to be replaced.
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
