Nokia N70 Cellular Phone Logo
Posted on Jul 31, 2008
Nokia N70 showing white screen.
Nokia N70 showing white light and flickering after startup only 1 time.Tried hard resetting but nothing is displayed still. please help ASAP.
  • sara944 Aug 09, 2008
    when my phone is on its flicker'one but not run
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Aug 06, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
Helped
4061
Points
16
Check the screen connection or get a new 1
White display.
Try to remove your memory card from your phone and then see if your phone starts properly. if it starts well, then there is a problem with your memory card. you must format your memory card before inserting it in to your phone.
If this doesn't works, hard reset your phone.
How to hard reset at Nokia N70?
Here are two ways to hard reset or format your Nokia N70 mobile phone:
Method 1
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key
3) Turn the phone on
Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Method 2
on the screen type *#7370#
you will be prompted for a Security Code. This is 12345 if you haven't changed it.
Do ensure that you have backed up your data first onto a PC by using pc suite, or onto a memory card.
3helpful
3answers
N70 display white please solution mee
Dear friend:
First get the lcd checked
Second connector of lcd
Third display driver crystal IC
Fourth get the smps ic power controller checked
Fifth get the line checked (lcd ic to lcd connector)
and last get the omap (cpu) checked
2helpful
2answers
Nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
56helpful
6answers
Display some time white some time abnormal
use a nokia restoration code. follow as prompt *#7370# /yes/your security code or default code and wait.
Nokia N70 Screen is White and shows NOKIA only
Open the back cover of the phone and remove the battery,the try blowing it hard where the battery pins are for 10 minutes or so then switch it back on.Your phone will run smoothly,but only for a short period.The best option is to press the *,green,3 at the same time after blowing the phone.if it does not want to work then let me [email protected]
3helpful
4answers
Nokia N70 Screen gets white blank
check your battery! i think you are using duplicate battery! put original battery to your mobile! again the problem came mean install new software and format your mobile
6helpful
6answers
NOKIA N70 SHOWS WHITE SCREEN AND FLICKERS!
faulty display or disply protection chips gone faulty
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
