Question about Samsung LN32A330 32 in. LCD TV
I have a samsung LN32A330J1DXZA 32 inch flat screen tv. not quite 2 years old and it wont turn on. red light just flashes once?
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 11, 2011
  • 11,361 Answers
It can be as simple as bad cpas, please look first for bad caps with domed tops in the power supply module as shown here in my albums:
http://s807.photobucket.com/albums/yy352/budm/Samsung%20LN32A330/
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
6ya staff
SOURCE:
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
I have a 32 inch Samsung TV that is only two years old. When you press the power button, it sounds like it it turning on and the red light comes on but the screen is black and there is no sound.
Main board is bad since it works with both video and audio. Ur backlights are ok so that omits the inverter board. And the T con board is for video only - since you have hassles with audio and video that leaves the main board. Do not think it is the power supply since your inverter board is powering up the back lights.
Nov 11, 2015 | Samsung UN39FH5000FXZA - 39in 1080p 240...
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
My tv wont turn on when i press the button, the red light at bottom right hand side of screen just flashes?
The capacitors in the power supply are bad. Take the back off, look at the capacitors, "barrels", if the top is bulging up, they are bad. Caps are around $2 each at radio shack x 6?
Feb 25, 2011 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Wont turn on
The power supply board has been defected. Replace it with a new one.
Aug 15, 2009 | Samsung LN32A330 32 in. LCD TV
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LN32A330 32 in. LCD TV Logo
1,500 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
