Tomtom ONE GPS Receiver Logo
Posted on Mar 11, 2011
How can i update new maps to my tomtom ? - Tomtom ONE GPS Receiver
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 11, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
1786
Points
24
You should have received a disc with your TomTom where you can install a program to your computer which gathers new up to date map information from the internet and then, after plugging the Tomtom into the computer and following steps to sync the unit, your GPS Receiver should be up to date with the latest maps.
In case you don't know where your CD is Tomtom's website has the program available for download.
Good Luck, hope this helps.
I would like to update the maps on my tomtom 610
To update the maps on your TomTom 610, use the MyDrive Connect software (from tomtom). If this tomtom software is not yet installed on your computer/laptop, download it from the tomtom website (e.g. www.tomtom.com) and install it. Then follow the instructions to update your map, after connecting your GPS device to your computer.
You may have to create a TomTom account (and register your device), sign in to your account, locate the replacement map or any new maps (of other regions) you wish to install, download the maps and install the map.
If you have a "lifetime" map (privilege) for your device, you won't have to pay (subscribe) for the updated map.
May 05, 2019 • Tomtom GPS
Does my tomtom have free new maps
If you had originally purchased a (new) TomTom with a "free" lifetime maps, you can download (from the tomtom website) updates to that map free, whenever that map is updated (usually four times a year).
If not, you can buy/subscribe to new maps on the tomtom website, (www.tomtom.com). Just click on "Maps & Services" ... and you'll be able to select and buy/subscribe to the map(s) you want.
May 10, 2016 • Tomtom GPS
How do I update maps on tom tom one from computer to GPS ?
Usually, you connect your TomTom to your computer, and use the TomTom software (e.g. HOME) to update (e.g. buy, download and install) your map(s).
If your question is about how to copy a (new / another) map on your computer to your TomTom device (i.e. without using the TomTom HOME software), you can simply copy the "map" folder (of the map on your computer) to your TomTom Device (that you've connected to your computer).
You may have other questions like, is there enough memory on your TomTom device for the map ?; is the (new/other) map version compatible for the TomTom (model/version) device that you have ?; is the map "activated" to run on your TomTom device? etc.
2answers
I have a tomtom go 720 and the maps have been deleted where can i go to get them back ?
register the device, tomtom home will reinstall the original map that was on the unit when new
1helpful
Free maps downlolad
If/when you've just purchased a (brand) new TomTom GPS, you can register it (at the TomTom.com website) and download the latest map (for your device) .... free ... as part of the latest map guarantee.
Whenever you connect your GPS to the TomTom website (via TomTom HOME), you'll get (free) updates to your current map version - ... but they are NOT new versions of the maps.
To get new versions of your (current) map, you'll need to purchase the update (e.g. online, on the TomTom website). Upon paying for it, you will get the activation codes, etc. for you to download, validate and install the maps.
If your GPS has lifetime maps, (after you have registered), you'll be able to connect (via TomTom HOME) to get the latest map release, without requiring any code/password.
Jun 21, 2013 • Tomtom GPS
2helpful
2answers
Update tom tom go 720 for free
You may be able to get "free" map updates from (illegal) underground sources. But that's not recommended.
Yes, you're right, you can simply get a new TomTom GPS and get the latest map(s) for it. Consider getting a TomTom with lifetime maps ....and you won't have to pay for any map updates.
1helpful
My tomtom go 700 is about 5 years old and i need to update the maps how do i start?
1.First of all check that TOMTOM actually still support this product and only perform updates using a wired network connection - WIFI can drop out and corrupt the downloads
2.Then see if they actually are supplying a new map for the 700
3.Without activating TOMTOM Home, plug your GO700 into your PC and let it recognise the 'drive assignment'
4.Take a FULL backup of all files on the TOMTOM 2Gb disk on your PC NOTE: this is totally separate and additional to any backups you might make with TOMTOM Home.
5.Disconnect your TOMTOM
6.Start your TOMTOM Home software and perform an update check from the 'help' drop down menu
7.Once you have this updated connect your TOMTOM
8.Perform a full backup again with the TOMTOM Home software
9.Search using TOMTOM Home for any GO700 application software updates and install these (NOTE - ONLY INSTALL THE APPLICATION UPDATES)
10.Reboot your GO700 to make sure that it works with any application updates
11.Re-connect your TOMTOM and this time perform a search for map updates to purchase and follow the instructions.
12.It is very likely that TOMTOM Home will say that there is not enough space on the drive to install the new map, it will follow an automatic process to remove your old map and then install the new one that you have purchased on lne from TOMTOM.
13. If Home has installed your new map correctly, when you log off and disconnect your GO700 it should then initialise - the long time bar rebuidling the maps and then start up normally. It can be necessary to reset your GO700 using the rest button under the base.
GOOD LUCK, This is currently a very messy process but one which seems to work for recovering the GO700 in the event of a failure, TOMTOM have been hopeless for me in getting any maps installed on a GO700, so this is my way of getting round their lousy support service.
3answers
Trying n to up date my tomtom for more maps in the usa
This is from tomtom.com
Hope this helps looks like you haveto pay for map updates after 30 days, but I am not positive.
Application updates
We recommend always having the latest version of the TomTom application installed on your navigation device. This ensures you can use the latest features and improvements available for your device.
To check if a new version is available, connect your device to TomTom HOME and then click Update my device. For more details see www.tomtom.com/6133.
Latest Map Guarantee
Get one free map update if a new map version is released within 30 days of buying a new device.
Start driving with the latest map - guaranteed!
See What is the latest map guarantee.
Map Share™
Get daily map changes from the TomTom community.
In between map releases, you can make corrections to your map – such as road closures, and points of interest – through Map Share™ technology.
See What is TomTom Map Share.
Map Update Service™
TomTom regularly releases brand new maps that incorporate the latest changes to the road network.
With our Map Update Service you get every new release of your map over a 12-month period, from the equivalent of just €9.95 per quarter. That’s four new maps a year.
See the TomTom Map Update Service.
Single map
If you only want to update your map once you can buy a single map.
Buy a single map.
4helpful
DOWNLOADING UPDATED MAPS
See the following options to update maps on your TomTom:
Map Share™
Map Update Service™
2answers
OUt of date map
go to www.tomtom.com
download 'tomtom home' to your PC.
this program will allow you to update the OS & let you buy new maps camera warnings etc.
You can buy them in your local stores too.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
