Washing Machines Logo
Posted on Jul 31, 2008
Water inlet valve problems
I have a w620 that the tub keeps filling up when not in use, and it just started filling really slowly and not washing the detergent into the tub. I assume the inlet valve/solenoid is failing, is it possible to get parts for this washer so I can repair it myself?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2773
Points
8
Repairclinic.com has parts available.
I have a toshiba washing machine model :aw-sd130sb: error code ec5. But this time solve the problem?
Ec5: Overloaded or insufficient water.
1. Your load of clothes is too large. Wash smaller loads.
2. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, see #1. try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
hope this helps
1helpful
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Set it going, fills up ok, goes through washing cycle but after spinning and then filling up for next cycle it overflows
Rather hard to understand your problem from the wording in the question but what I understand to be the case is that your tub fills up with water and overflows after the cycle is finished. Perhaps overnight water slowly fills the tub. This is due to the water inlet valve not shutting off all the way. The Inlet valve assembly needs to be replaced.
2helpful
Water filling up slowly in the tub
The problem can actually be caused by the water inlet valve leaking by, or a faulty pressure switch. Both are fairly simple to replace. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I have included steps on how to replace both parts, and web resources to search for replacements. If the model number is correct, the replacement part numbers you may need are:
Water Inlet Valve - 8181694
Pressure Switch - 8181695
If you have any questions about this repair, please post back and let me know. I hope this helps you.
1helpful
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
2answers
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
1helpful
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
3helpful
Slow water delivery into machine
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Q - My washer fills slowly with water, what can I do ?
A - Two things could be your problem...
1) - sometimes the screens in the fill valve or inside the ends of the fill hose get clogged up...use a tooth brush to clean them out. Don't forget to shut off the water first before removing the hoses to check for this.
2) - The fill valve itself may not be opening fully = time for a new fill valve.
Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Top Asko Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
