Your gunning your amp too hard, the electrical prostate is being overloaded and it cums
The ohm load may be too low. What make/model amp is it?
Does it do it if you use only one speaker?
The amplifier has low voltage protection (if it's like similar Infinity amplifiers). If the voltage isn't remaining at or above 12v, the amp could be shutting down from low voltage. If you see the voltage drop below 12v on a multimeter (connected across the B+ and ground terminals of the amplifier), the voltage is actually dropping significantly lower because multimeters are relatively slow to respond. If it shuts down more quickly with the engine off, this could be the problem.
The problem is unlikely to be from a bad shield ground on the RCAs. That's more likely to cause the amp to oscillate or have excessive engine noise.
When the amp shuts off, does the power light go off or does the protection light come on?
If the wiring for the speakers isn't shorted to the body of the vehicle (under the corner of the box), I think the amp is defective (especially if it shuts down driving 4 ohms and the voltage isn't dipping below 12v). You'll have to have a technician check it out.
If you can reproduce the problem on the bench, it should be easy to determine which of the protection circuits is being triggered. I have the service manual. Email me and I'll send it to you.
[email protected]
its a infinity 1600a not an over load i had it wired for 4ohms and it did the same.
checked the remote and 12v yesterday it was dipping below 12v. but now its staying at about 13v and its still cuts off. yesterday i thought for sure that was it this but today iam not sure .. if i keep the volume lower i can get more bass but then the voices aren't loud enough. any more suggestions
the protection light comes on
i am a tech. i came here because i have never seen this problem before. i had a diferent amp in and it still does it . when i first turn the system on the protect light comes on then goes off the music plays before the bass comes in. With this amp and the other . the other was a directed 404. ill check it out alittle more today
