HP Color LaserJet 2600n Printer Logo
A
Anonymous Posted on Mar 12, 2011
Sir i have another problem , I have HP 210-1033tu when i got the machine it have windows XP home edition installed , right now i dont have any recovery backup and my machine crashed, i have tried many times to install XP but every time the BLUE Screen of death comes , but when i installed windows 7 it is installed, i dont want windows 7 i need XP, kindly give me the solution
Patrik Parker
Level 3:
Master:
  • Master 148 Answers
  • Posted on Jul 10, 2019
Patrik Parker
Master
Level 3:
Master:
Answers
148
Questions
5
Helped
8407
Points
2578
Call Our Customer Service and Support Call 1 8O5*465*751O Toll Free
24x73333
Anonymous
Level 3:
  • HP Master 1,591 Answers
  • Posted on Mar 12, 2011
Anonymous
HP Master
Level 3:
Answers
1591
Questions
Helped
414084
Points
4899
MAny programs that "require" windows XP to install, can be told by windows7 that they are being installed in XP by installing them in a XP compatibility mode.
Open up Computer, and choose the C drive
If it prompts you with a security warning, tell it to open it anyways.
Create a new folder on the C drive (if you were trying to install Corel Draw for example, make a folder called Corel CD)
Open computer again and right click the CD drive, and select open.
Re-size/move this window so that you can still see the C:\corelCD folder (for example)
single click any file or folder in the CD's main folder, and press CTRL-A then CTRL-C
Click anywhere in the new folder you created (ie, c:\corelCD) and press CTRL-V
once all the files are copied, single click the SETUP or INSTALL icon (Ususally Setup.exe)
right click and choose properties
Click the Compatibility tab at the top, and choose compatibility for XP Service Pack 3
also choose run as administrator.
Click OK
Now double click the setup.exe and it should install under windows7 without issues
Before HP had win7 drivers for many of our printers, that was the unofficial fix to install the print driver from the CD to win7.
Later downloads were offered off the website that didn't have this issue - but when a lot of those failed, it was back to "here's how to install the original XP driver" as a solution!
Good Luck!
1helpful
5answers
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
I had a orginal windows xp home with product key but i had installed xp professional pirted edition can i convert it into xp home orginal?
No sir you can just convert your windows into xp home original.you will have to format the pirated windows which you have then re-install your new xp home into it
use your xp home cd to format your hard disk by booting your system with the xp cd and then install your windows
Feel free to ask anything
Thanks
2helpful
I cannot install ethernet driver of hp compaq d530. Where can i find it?
Hello: I hope the following information is helpful.
If you are trying to install the driver for the Broadcom ethernet NIC that was pre-installed (NOT an ethernet card that you purchased and installed yourself), there is a softpack (updated driver installation) download available from HP/Compaq. It will install the driver automatically for you, just download it from the link below and run the ".exe" file.
IMPORTANT: Check to be sure that your current Operating System, and model of the network device you are trying to install, are BOTH listed below BEFORE you download!
This is a software / driver update for the HP Compaq d530 ultra-slim desktop: All Models
Supported network devices:
BCM5906M Broadcom 10/100/1000 5782 based NIC Broadcom 570x 10/100 Integrated controller Broadcom NetXtreme Gigabit Ethernet 5782 Broadcom NetXtreme Gigabit Ethernet PCI-Express NetXtreme(tm) 10/100/1000 Gb NIC
Supported Operating Systems: Microsoft Windows 2000 Microsoft Windows 98 Microsoft Windows NT 4.0 Microsoft Windows Vista Business 32 Edition Microsoft Windows Vista Business 64 Edition Microsoft Windows Vista Enterprise 32 Edition Microsoft Windows Vista Enterprise 64 Edition Microsoft Windows Vista Home Basic 32 Edition Microsoft Windows Vista Home Basic 64 Edition Microsoft Windows Vista Home Premium 32 Edition Microsoft Windows Vista Home Premium 64 Edition Microsoft Windows Vista Starter 32 Edition Microsoft Windows Vista Ultimate 32 Edition Microsoft Windows Vista Ultimate 64 Edition Microsoft Windows XP Home Edition Microsoft Windows XP Professional Microsoft Windows XP Professional x64 EditionINSTALLATION INSTRUCTIONS: 1. Download the file by clicking the "Download" or "Obtain Software" button and saving the file to a folder on your hard drive (make a note of the folder where the downloaded file is saved). 2. Double-click the downloaded file and follow the on-screen instructions.LINK where file can be downloaded:HP/Compaq Support-Broadcom Driver download
Again, I hope this information is what you neededto install your network device. Should this not answer your question, please come back, provide more details of your problem, and we will be happy to help!Best of luck to you!
Lost my xp home edition codes can u give me one to use
sorry sir u will need to calll Microsoft a do u have the original xp cd if so the cd should have it on the cd if u plug it into a machine that works then right click on the cd under my computer/ then ur going to hit explore/open
1helpful
2answers
Installation windows xp home throught internet already have product key
Well, if you have a friend or neighbor who has Window XP Home, you could borrow their CD, but use your product key during the installation.
Please send win98se driver for hp laptop model no. nx7300
Hello sir.
I understand that you need windows 98 drivers for your Notebook.
I have searched the HP website and found the drivers for the following operating systems.
Microsoft Windows XP Home edition
But not for Microsoft Windows 98...
Windows 98 is considered to be obsolete now. As far as I know no one will provide drivers for this model Notebook for Windows 98. Please install atleast Windows 2000 in the Notebook for the drivers to work correctly.
For other operating system drivers other than Windows 98 could be found in the following link..
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3310302&taskId=135&prodTypeId=321957&prodSeriesId=3310301&lang=en&cc=us
I have the key to Windows xp home but I dont have the CD
sir, of course you need a cd. cd key were use to unlock the serial key and thats the only help of the cd key.
CHARCOIS
Hp drivers
necesito recuperar mi wireles lo borre y no se que hacer
Windows Xp Home edition Installation
Hi tross202;
Is that an original XP home edition installer? You may try another cd installer if you can secure one.
k24674
Grand Canyon Tech
Grand Canyon Tech
