On my 1998 honda accord i need to know how to reset the maintenance required light.
Hi.. after you do this step come back and rate as fixya. OK..
Turn the ignitio key to run position
Push and hold for 5 seconds the Trip reset botom.
With the botom pushed turn the ignition key to OFF position.
Keeping pushed the botom.
Turn the Ignition switch to RUN position. keep pushed the trip botom for 10 seconds or untill you see the MAINT_Requi. go OFF.
Remember all this steps with the trip botom pushed. OK.
I hope this solve your question. Thank you for use fixya.
Press reset/trip button, hold it in, turn key to 'on' position, this is the position right before cranking where your dashboard should light up. hold the button for 10 seconds.
Sit inside the driver's seat of the Honda Accord and close the driver's side door. Any interior lights on can prevent the maintenance required light from resetting properly on some year models.
Insert the key in the ignition.
Depress the odometer/trip button located beneath the odometer on the instrument panel. Hold the button down.
Turn the ignition key two clicks forward to the accessory power position. This is also known as the key-on/engine-off position.
Continue to hold down the odometer/trip button for up to 15 seconds until the maintenance required light goes out. On some Accord models, the maintenance required light may blink once before going out.
Release the odometer/trip button and then turn the ignition key to the off position.
Start the Honda Accord to ensure the maintenance required light is no longer illuminated on the instrument panel. If it still is, the reset procedure did not take and you'll need to repeat the procedure.
