Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit.. Which will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
