Question about GE Washing Machines
GE Profile Hydrowave Model # WPRE6100G1WT Washer fills then never washes goes thru the cycle will drain better never spins. The inline fuse is ok. No light on the inverter to check codes. Is the motor bad?
    Brigadier General:
  • 6,277 Answers
It COULD be the motor but it could also be a number of causes such as wiring, control PCB etc.
Draining is carried out by a separate motor. I fear a service call is required to investigate and diagnose, sorry ;-0(
Good luck,
John C
Posted on Mar 12, 2011
6ya staff
SOURCE:
Will not spin the water out of the clothes
call a repairman sounds like a controller problem or transmission not getting final rinse signal
Mar 15, 2015 | GE Profile PTWN6050MWT 27" Top-Load Washer...
Washing goes thru fill cycle, and spins, clothes still wet and soap still in machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 09, 2011 | GE WBB4500EWW Top Load Washer
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Washer won't cycle past fill, keeps returning to fill cycle
That could be excess detergent causing the control to do extra washes to get rid of detected Suds. On these washers it is critical to use HE detergent and the right amount. Most often directions on detergent boxes are useless. This washer has a 3 phase motor with an inverter to change the current from 120 to 200 volts dc. If you continue to use wrong amounts of detergent the inline fuse will eventually blow from the motor overheating trying to correct overdose of detergent. Read more about it in the GE HYDROWAVE SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 24, 2010 | GE WHRE5260E Top Load Washer
There is power to the washer, water will drain
Try unplugging machine for 30 seconds then plug back in then lift and close the lid 5 times which will reset the motor. Try the spin cycle if it works you may have had a power surge which took the motor out and just needed reset. If it fails you may have a bad inline fuse or motor.
Feb 26, 2010 | GE Profile WPRE6100G Top Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
No agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Dec 01, 2007 | Washing Machines
Washing Machines Logo
244 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
