Question about Konica Minolta DiMAGE Z6 Digital Camera
8 Gb SD card not recognized by Minolta DiMage Z6 digital camera. What is maximum size SD card this camera can address?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Konica Minolta Master
  • 102,366 Answers
The Z6 works with MMC and SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
Posted on Mar 12, 2011
6ya staff
SOURCE:
What is the maximum size sd card I can use? Mahalo for your assistance
This camera model is about 12 years old now and most cameras of the age had small memory cards as the camera produced relatively small image files. The camera was supplied with a 16 Mb (not Gb) SD card so I wouldn't have thought the maximum capacity would be much over 64Mb.
Check this http://www.dpreview.com/reviews/konicaminoltaz5/2
Sep 16, 2015 | Konica Minolta DiMAGE Z5 Digital Camera
Is there an up-date which will allow dimage Z6 to use a 4 GB storage card please. My camaera will only recognise up to 2GB SD card.
Sorry, no. SD cards max out at 2GB. Larger SDHC cards are electronically incompatible and will only work in devices specifically designed to accept them. It's a hardware incompatibility and no amount of firmware changes will make a SD device accept SDHC cards.
Jan 30, 2013 | Konica Minolta DiMAGE Z6 Digital Camera
The Konica Minolta DiMAGE Z6 will not read the 8 GB card
The Z6 uses MMC and SD cards. If you look carefully at your 8GB card, you'll see that it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. The Z6 is limited to cards 2GB and smaller.
Oct 13, 2011 | Konica Minolta DiMAGE Z6 Digital Camera
Konica minolta dimage z6 card locked. how do i unlock it
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 19, 2011 | Konica Minolta DiMAGE Z6 Digital Camera
Minolta Z6 SDHC memory limits? Only a 2gb standard SD seems to work. Any input?
The Z6 works with SD and MMC cards. It does not work with SDHC cards at all, whatever their size. SD cards are limited to 2GB in size.
Jul 27, 2010 | Konica Minolta DiMAGE Z6 Digital Camera
Am I able to use a 2GB SD card in my Konica Minolta Dimage G400 camera or could this cause problems.
This camera has been discontinued, and is no longer sold as new. There are still vendors that sell accessories for this camera including batteries and SD memory cards. A google search of "dimage g400 memory" reveals a number of retailers that sell SD cards of varying sizes up to 2 GB specifically for this camera.
Going beyond 2 GB however, will probably give mixed results, as most cards 4 GB (the next size up from 2 GB) are SDHC type cards. An SDHC card looks identical to the SD counterpart, but is manufactured to a different specification. The SDHC specification was developed after you camera was made, so use of cards bearing the SDHC mark is not supported.
I hope this helps!
Oct 30, 2009 | Konica Minolta DiMAGE G400 Digital Camera
Unable to use card
Firstly, what size memory hard do you have? Is it an SDHC? Secondly, have you checked that the memory card isn't locked (there is a switch on the side of it). Has it worked with other memory cards?
May 07, 2009 | Konica Minolta DiMAGE Z6 Digital Camera
I was told last year when I researched it from the website, only a 2 GB card could be used.
Jul 22, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Konica Minolta DiMAGE Z6 Digital Camera Logo
1,102 people viewed this question
Top Konica Minolta Cameras Experts
Ekse
 Larry
Larry
Pierre Laplante
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
