Hi this could be several reasons for not working firstly it could have been liquid damaged /spillage etc check keys are they sticking when pressed if so you will need to remove panel and remove keypad and clean the unit iff this fails check lead at base of keypad entering the board this might have come lose or even broken away .you might even try changing the keypad if all fails hope this helps you
Hi gyengestefan, you need to "Update the Driver / Software!" "Select the [Drivers] you need from the "List." "Download the Drivers!" !Important: "Take a 'moment to rate the help', so I can get 'credit' for the work. Thank you!" - paul7of9
"Go to this "Website!"
Fill-in necessary information.
ie: Model #, Brand, and or Operating System...
"I could have given a "Thousands" Senarios / Reasons / Hypothesis / Theories; why its not working!"
"I gave (1); a solution to fix the Problem!"
I receive lots of laptops with this problem and its mostly down to spillages ,coke cola is the worst possible liguid that can be spilled but still people drink it coffee tea whatever it may be very easy to clean though if liquid manages to hit the motherboard then you have a serious problem like blue screen etc .
This 'comment' is for FixYa! So my understanding is; -10 is {subtracted} for "Not Helpful: Solutions!" But! When the "Solution is Very Helpful! = 5 or < LESS!" ? Is this "Correct"!? I have another ?Question? Do a number between a (100 to 1000) people respond quicker, and more to "Solution that do not help!" In comparison to the "Solutons that do?"
SOURCE: i need a vedio on how to put back the space bar
http://www.buy.com/retail/product.asp?sku=213651502&listingid=74483592
just replace the whole keyboard. Those keys are just gonna fall right off later.
SOURCE: reload original XP pro back
You can download any orall the Windows XP or Vista device drivers for your model laptop from theToshiba WEB site from their download page. Make sure you enter the model ofyour laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
SOURCE: key board don't work on
If your keyboard won't work, then it means you will have to do replace it. But before that, you will have to check first if the keyboard isn't disabled on your PC.
Go to Start > Control Panel > Keyboard.
Select hardware, select your keyboard name, then click properties. Click Change settings, click drivers and check if your keyboard was uninstalled or disabled. If it was disabled, you can enable it.
But if the above isn't the cause of the problem, get a USB keyboard (external keyboard), insert it into the USB port of your Toshiba protege m400 and it should work pending the time you have your keyboard replaced.
Good luck.
