Contributor
- Posted on Mar 13, 2011
Re: My Hotpoint Aquarius WM62P won't drain. I lowered...
Use a pair of pliers (like water pump pliers) and use them to grab and pinch open the metal spring clamps. then while holding them open, move the spring down off of where it was so that you can pull the rubber tube off of where it is connected on.
Sorry, I don't know your particular machine. Can you see and confirm that the filter and pump are actually in that position, please? I've not come across one with gold coloured spring clamps before- but that's not particularly surprising!
If you are sure then you will have to use a screwdriver or similar to 'spring' them off BUT please ensure it's the right place first and that the filter is not behind the FRONT lower panel!!
Good luck,
John C
