I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
Yeh...I have the same problem and can't find a solution anywhere!...come on you techy guys....surely someone can find the answer?, or am I destined to be in control of the channels and "the other arf" controls the volume!
come on ! we need help here !!!
cannot find sky remote code for 42lg3000 using 2 remotes does my head in! john
Any luck guys? In need of same solution...
