Westinghouse LCM-22w2 Television Logo
Posted on Mar 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My blueray dvd player isnt working because the tv resolution is set on mono 480p how do i change it back to 1080p to get my blueray to play again
Anonymous
Level 2:
  • Expert 902 Answers
  • Posted on Mar 14, 2011
Anonymous
Expert
Level 2:
Answers
902
Questions
0
Helped
179612
Points
142
Under the settings in westing house there is an option for minimum resolution deselect 480p and select 720p and higher.
1helpful
How do i change from 480p to 1080p on my rca remote
You don't. The TV's resolution can't be changed. Only the signal resolution from the source can be altered.
The TV reports the resolution of the incoming signal before it is scaled. If you have a BD player you can see the effect of changing the resolution setting from 480p, to 720p, to 1080i, to 1080p 60, to 1080p 24. The last three (the 1080 resolutions) shouldn't look too different with a Blu-ray apart from movement because the native picture is 1080p 24 and the TV is simply converting it back to 1080p 24 for display.
How to set display to 1080p on Hisense F42K20E?
You don't. The TV has a resolution of 1920 x 1080 pixels; so it's already 1080p. The number of pixels can't be changed.
What you're probably getting mixed up with is the TV showing the resolution of the incoming signal when you change channels or go to a different source. Standard definition from cable might be flagged as 480i. DVD might show either as 480i, or 480p, or maybe 720p or 1080i or 1080p if you have a scaling DVD player and set it appropriately. HDTV on cable or satellite will show as 1080i or possibly 720p. Blu-rays and PS3/XBox 360 or PS4/Xbox One should show as 1080p when your TV is connected.
Whatever the source signal resolution, the TV will scale it up to fill the panel area of 1920x1080 pixels. So the TV is always using all the pixels, regardless of the resolution of the source signal.
Panasonic th 46pz80u
Yo don't. The TV's resolution can't be changed. Only the signal resolution from the source can be altered.
The TV is a fixed pixel device. The panel has a resolution of 1920x1080 pixels. The incoming video signal is scaled to fit that display. If the signal is 480i then it is deinterlaced to make it 480p, and then scaled up to make it 1080p. The amount of detail in the picture doesn't change. It's still a 480i image. It's just blown up to fill a 1080 panel.
960i is a funny resolution. That would be achieved by line doubling a 480i signal. But it's not one of the VESA HDTV timings. TTBOMK there's no Blu-ray or HD source that generates a 960i image. So even if you could generate it then the TV wouldn't understand what to do with it.
2helpful
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
2helpful
How do I go from 480p to 1080dpi on my 65inch HDTV
If you're using an HDMI cable your display will automatically adjust the settings based upon the video source. Make sure that your source is capable of outputting 1080p. If it's an HD Cable Box or DVR, the maximum resolution it can display is 1080i. If you have one of these HD boxes, set it to only display 1080i as there will be a delay every time you change channels from a channel that is not naturally at 1080i.
If your source is a standard DVD player, it can only display images in 480i (or 480p if it is Progressive Scan) and therefore your TV will display the picture in 480 resolution. If your source is an upconverting DVD player it will display up to 1080p however, Keep in mind that DVD's are in 480 resolution and that regardless of upconversion (or upscaling, though improved, the picture will not be in HD.
The only way to achieve a true 1080p (not dpi... that's dots per inch... that's a printer term. The "p" is for Progressive Scan as opposed to an "i" for Interlaced) is from a 1080p source, i.e., a Blu-Ray disc player playing a Blu-Ray Disc with the use of an HDMI cable. Component Cables can achieve 720p/1080i only with your TV as it does not support 1080p over component cables.
As an aside, there are some media players that support 1080p output and some DirecTV Boxes and DVR's d oas well for 1080p Pay Per View movies.
Philips DVP 3982, 4 months old, hdmi connected to vizio tv. Suddenly now it plays sound but not picture. If I hook it up with composite cables it works, but of course the picture isn't very good. I tried a...
I have few options for you to get the video back on HDMI:
1. Try out changing the video resolution on HDMI set up (select 480p..1080p).
2. Play NTSC disc (to get the 60Hz out from Player). If your are in US.
3. Select the TV system as AUTO/NTSC to get the 60Hz out only on HDMI.
4. if the Deep Color option is available in HDMI set up menu..set it to OFF.
Let me know if you tried all these and still no output.
1helpful
Tv is showing 480p and we want it at 1080p on our new Toshiba 40XV648 40-Inch 1080p 120Hz HD LCD TV Cinema Series.
After searching the owners manual I find that there is nothing mentioned about the screen resolution i.e. 480p to 1080p.
This set is capable of your desired resolution and as far as I can tell it auto selects because it senses the input video and decides which is the best setting for that source.
It's important to understand that you need 1080p video to use it at it's full capabilities. It won't give you a 1080p resolution from a VCR or a standard DVD player. You need a DVD player that is capable of producing a 1080p encoded video. Some satellite receivers are capable of that but you need to make sure you know what resolution that you are sending to the television.
Local TV stations won't usually broadcast HD at 1080p. Your best bet is to use a DVD player that is capable of that high resolution for your best picture.
Please note that what it says in the owners manual about "Resolution" has nothing to do with the 480p, 720p or 1080p signals, your set selects that automatically it will start by selecting the 1080p then goes to 720p then 420p it's dependent on the video you send to the set.
Please note the "resolution" function is actually like a "sharpness" control.
Your video input (tuner, VCR, DVD, games and etc.) is likely your problem.
2answers
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Setting ***.
You will have to change the dvd player resolution to 1080i (or change resolution for each individual disc), because:
a) there is no way to change the resolution manually on this television
b) this TV maxes at 1080i, hence negating most of the utility of using an hdmi cable (Of course, hdmi cables are much easier to hook up, less messy than component cables; so all is not lost)
4answers
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
