Bosch Exxcel WVT 2850 Front Load Washer / Dryer Logo
Posted on Mar 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to buy a new door seal for my bosch wvt 1260 washine machine. can you advise where? thanks
How-2-Repair.com
Level 3:
  • Bosch Master 746 Answers
  • Posted on Aug 05, 2013
How-2-Repair.com
Bosch Master
Level 3:
Answers
746
Questions
0
Helped
592522
Points
1880
how to change a door seal.
This video will show you how to change a door seal on this Bosch front loader washing machine and where to get a new door seal!
we have all
bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
Level 3:
Brigadier General:
  • Master 6,277 Answers
  • Posted on Mar 14, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
6277
Questions
0
Helped
1026549
Points
20216
Sorry. As we are scattered all over the world it would be difficult for anyone on the forum to tell people where their 'local' suppliers are, even if we knew where they were ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
Good luck,
John C
Can I replace the rubber seal on my Bosch washer 500 series
How to Replace the Door Seal on a Washing Machine ...
eSpares https://www.espares.co.uk > ... > Washing Machines
Gently pull the seal away and work it around the band to remove it. Keep the retaining band to one side and pull the door seal out. Step 9: Fit your new door ...
Bosch Door Gasket : Appliances
Amazon.com https://www.amazon.com > Bosch-BOSCH-CLOTHES...
Buy Bosch Door Gasket: Washer Parts & Accessories - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Rating: 4.4 · ‎83 reviews · ‎US$84.93 · ‎In stock
Videos showing how it is done.
How to replace door seal on washing machine Bosch Advantixx ?
How to Replace the Door Seal on a Washing Machine - Bosch
One of the most common faults of a leaking washing machine is a faulty seal. Thankfully replacing such a component of your washing machine is not a difficult task.
In the above video, with the help of our experienced team, we explain how to replace the washing machine door seal, and below we've compiled a simple step-by-step guide which takes you through every point covered in our video.
Step 1: To remove the door seal on any make and model of washing machine, you'll need to remove the entire front panel, followed by the soap dispenser and fascia.
Removing the panel and fascia is easy to do, once you've undone the screws holding it in place, whilst the soap dispenser should just clip out of place.
Step 2: With these components removed, clip away the kick plate, put the drain hose to one side before removing the retaining clip which holds the door seal against the front of the machine. Once the clip has been removed just push the seal inside.
Step 3: Undo the four remaining screws holding the front of the machine on, before pulling the front of the machine and the door away from the machine.
Once the front of the machine is off, you should be able to see the spring retaining band going all the way around thedrum. This should be easy to pull off, enabling you to peal the whole old seal away; once you've removed the old seal this can be thrown away, although it is advisable to keep the retaining band, as this can be reused with the new seal.
Step 4: You'll now be ready to attach the new seal, when doing so make sure that the drain holes are positioned at six o'clock; once you've done this it is just a case of working the new seal onto the drum.
With the seal worked onto the drum, put the retaining spring into its little ridge, before giving the seal one final check.
Step 5: Reattach all the parts back to your washing machine, attaching the door seal to the front of the machine ensuring that it goes over the lip, before attaching the retaining band on the bottom and sides.
There you have it, a step-by-step guide to replacing the door seal on a washing machine, helping it to perform to its optimum level.
SAJID
How to Replace the Door Seal on Washing Machine Bosch
Bosch washing machine WVT 126S, error F01 on the start. Please help
F01 means the machine thinks that you have pressed start and the door is still open, so, either the door is not completely shut or you will need a new door interlock (part number 182154) you can get the part by calling 0844 892 8979 (UK) or http://www.bosch-home.co.uk/customer-service/spare-parts-accessories.html. Or the connection to the door lock is not loose or detached.Hope this helps
BOSCH WVT 1260 is malfunctionig, as i put the male-plug to the 220 volts, it gives a sounds of tu-tu-tu-tut, a key is showing on the digital screnn.
From your description I would suspect there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
2answers
Replacement part
Bosch Nexxt DLX WFMC4301UC door seal replacement
parts
This video will show you how to change a door seal on this Bosch front loader washing machine and the best
places to buy parts.
we have all
2answers
Where can we buy a door seal for Bosh Axxis in Toronto? Thanks!
we have all bosch repairs in our channel
You can get seals on eBay
Milldew in washine machine.
You can't remove it ,you would have to replace door seal,the cause is becoming very common,people are washing at lower temperatures,the mould is fungus,its alive higher temperatures kills it.Close Ire.
3helpful
4answers
BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
2answers
Replacement door seal/gasket
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
1helpful
Bosch wvt 1260
dry heater is located under an aluminium housing on top of the machine. take it to bits and easy to fit. however, why do you need a heater? if no heat on dry, cause is probably overheat stat operated
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
