Howdy,
If you post the make and model of your stereo, & maybe your truck too, I wll try to help you troubleshoot.
Also, maybe describe what your head unit (stereo) is doing, ie does it seem to have power, is it acting appropriately to the key being off, on & the motor running positions?
No one should be without tunes, I'd like to help.
Probably have two or more wires that need to be connected to another wire, but not enough information to truly diagnose.
if you look really close at the wires they should have some very small writing on them that tell you what they are for.... what is the model of the radio, maybe i can look up a diagram, are these wires from the car, or the radio
ok try connecting the ant wire to the acc wire, the remote wire is only needed for amp for like subwoofers, dimmer and illumination should be hooked up to a power wire i beleive they are s switched function.
the orange dont need to be connected but the pwr ant wire does, also check that the red and yellow and gnd are attached properly.
there r still two orange wires and two blue wires left over but idk where to connect them
the orange r illumination and dimmer the blues r amp rem and ant rem
its a sony and the blues r from the radio the orange from the harness
so should the ant wire go to the yellow wire ?
